Datasheet Wago 771-8992/005-305 — Даташит
предв. собранный межблочный кабель; Eca; Розетка - штекер; 2-пол.; Код. B; Контрольный кабель 2 x 1,0 мм²; 3 м
| 771-8992/005-507 Wago | по запросу | ||
| Coding | B |
| Цвет | light green |
| Color of sheathed cable | gray |
| Connection type | Socket - Plug |
| Connector color | light green |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 5.9 … 7.5 mm |
| GTIN | 4055143370554 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | 1 2 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Number of Poles | 2 |
| Packaging type | not packed |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | 1 2 |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | white |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 3 m |
| Total number of potentials | 2 |
| Type of cable | Control line 2 x 1 |
| Type of cable assembly | Interconnecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 164.57 г |
Серия: 771 (100 из 3186)
- 771-8985/207-304 771-8985/207-403 771-8985/207-404 771-8985/207-503 771-8985/207-504 771-8985/207-603 771-8985/207-604 771-8985/207-703 771-8985/207-704 771-8985/207-803 771-8985/207-804 771-8985/216-103 771-8985/216-104 771-8985/216-203 771-8985/216-204 771-8985/216-303 771-8985/216-304 771-8985/216-403 771-8985/216-404 771-8985/216-503 771-8985/216-504 771-8985/216-603 771-8985/216-604 771-8985/216-703 771-8985/216-704 771-8985/216-803 771-8985/216-804 771-8985/217-103 771-8985/217-104 771-8985/217-203 771-8985/217-204 771-8985/217-303 771-8985/217-304 771-8985/217-403 771-8985/217-404 771-8985/217-503 771-8985/217-504 771-8985/217-603 771-8985/217-604 771-8985/217-703 771-8985/217-704 771-8985/217-803 771-8985/217-804 771-8992/005-103 771-8992/005-105 771-8992/005-107 771-8992/005-203 771-8992/005-205 771-8992/005-207 771-8992/005-303 771-8992/005-305 771-8992/005-307 771-8992/005-403 771-8992/005-405 771-8992/005-407 771-8992/005-503 771-8992/005-505 771-8992/005-507 771-8992/005-603 771-8992/005-605 771-8992/005-607 771-8992/005-703 771-8992/005-705 771-8992/005-707 771-8992/005-803 771-8992/005-805 771-8992/005-807 771-8992/006-101 771-8992/006-102 771-8992/006-103 771-8992/006-105 771-8992/006-107 771-8992/006-201 771-8992/006-202 771-8992/006-203 771-8992/006-205 771-8992/006-207 771-8992/006-301 771-8992/006-302 771-8992/006-303 771-8992/006-305 771-8992/006-307 771-8992/006-401 771-8992/006-402 771-8992/006-403 771-8992/006-405 771-8992/006-407 771-8992/006-501 771-8992/006-502 771-8992/006-503 771-8992/006-505 771-8992/006-507 771-8992/006-601 771-8992/006-602 771-8992/006-603 771-8992/006-605 771-8992/006-607 771-8992/006-701 771-8992/006-702 771-8992/006-703
7718992/005305, 771 8992/005 305
