Datasheet Wago 771-8992/006-803 — Даташит
Соединительный кабель
| 771-8992/006-407 Wago | по запросу | ||
| Coding | B |
| Цвет | gray |
| Color of sheathed cable | gray |
| Connection type | Socket - Plug |
| Connector color | gray |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 6.8 … 8.6 mm |
| Fire load | 9.226 MJ |
| GTIN | 4050821871293 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | 1 2 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Number of Poles | 2 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | 1 2 |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | white |
| Product Group | 20 (WINSTA) |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 8 m |
| Total number of potentials | 2 |
| Type of cable | Control line 2 x 1.5 |
| Type of cable assembly | Interconnecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 543.426 г |
Серия: 771 (100 из 3186)
- 771-8992/005-407 771-8992/005-503 771-8992/005-505 771-8992/005-507 771-8992/005-603 771-8992/005-605 771-8992/005-607 771-8992/005-703 771-8992/005-705 771-8992/005-707 771-8992/005-803 771-8992/005-805 771-8992/005-807 771-8992/006-101 771-8992/006-102 771-8992/006-103 771-8992/006-105 771-8992/006-107 771-8992/006-201 771-8992/006-202 771-8992/006-203 771-8992/006-205 771-8992/006-207 771-8992/006-301 771-8992/006-302 771-8992/006-303 771-8992/006-305 771-8992/006-307 771-8992/006-401 771-8992/006-402 771-8992/006-403 771-8992/006-405 771-8992/006-407 771-8992/006-501 771-8992/006-502 771-8992/006-503 771-8992/006-505 771-8992/006-507 771-8992/006-601 771-8992/006-602 771-8992/006-603 771-8992/006-605 771-8992/006-607 771-8992/006-701 771-8992/006-702 771-8992/006-703 771-8992/006-705 771-8992/006-707 771-8992/006-801 771-8992/006-802 771-8992/006-803 771-8992/006-805 771-8992/006-807 771-8992/007-101 771-8992/007-102 771-8992/007-201 771-8992/007-202 771-8992/007-301 771-8992/007-302 771-8992/007-401 771-8992/007-402 771-8992/007-501 771-8992/007-502 771-8992/007-601 771-8992/007-602 771-8992/007-701 771-8992/007-702 771-8992/007-801 771-8992/007-802 771-8992/016-101 771-8992/016-102 771-8992/016-201 771-8992/016-202 771-8992/016-301 771-8992/016-302 771-8992/016-401 771-8992/016-402 771-8992/016-501 771-8992/016-502 771-8992/016-601 771-8992/016-602 771-8992/016-701 771-8992/016-702 771-8992/016-801 771-8992/016-802 771-8992/017-101 771-8992/017-102 771-8992/017-201 771-8992/017-202 771-8992/017-301 771-8992/017-302 771-8992/017-401 771-8992/017-402 771-8992/017-501 771-8992/017-502 771-8992/017-601 771-8992/017-602 771-8992/017-701 771-8992/017-702 771-8992/017-801
7718992/006803, 771 8992/006 803
