Datasheet Wago 771-8992/206-307 — Даташит
предв. собранный соединительный кабель; Eca; Штекер/открытый; 2-пол.; Код. B; Контрольный кабель 2 x 1,5 мм²; 3 м
| 771-8992/207-401 Wago | по запросу | ||
| Coding | B |
| Цвет | pink |
| Color of sheathed cable | gray |
| Conductor preparation | tip-bonded |
| Connection type | Plug - free end |
| Connector color | pink |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 6.8 … 8.6 mm |
| GTIN | 4055143503952 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | 1 2 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Number of Poles | 2 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | 1 2 |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | white |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 35 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 3 m |
| Total number of potentials | 2 |
| Type of cable | Control line 2 x 1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 206.643 г |
Серия: 771 (100 из 3186)
- 771-8992/117-201 771-8992/117-202 771-8992/117-301 771-8992/117-302 771-8992/117-401 771-8992/117-402 771-8992/117-501 771-8992/117-502 771-8992/117-601 771-8992/117-602 771-8992/117-701 771-8992/117-702 771-8992/117-801 771-8992/117-802 771-8992/205-103 771-8992/205-105 771-8992/205-107 771-8992/205-203 771-8992/205-205 771-8992/205-207 771-8992/205-303 771-8992/205-305 771-8992/205-307 771-8992/205-403 771-8992/205-405 771-8992/205-407 771-8992/205-503 771-8992/205-505 771-8992/205-507 771-8992/205-603 771-8992/205-605 771-8992/205-607 771-8992/205-703 771-8992/205-705 771-8992/205-803 771-8992/205-805 771-8992/206-101 771-8992/206-102 771-8992/206-103 771-8992/206-105 771-8992/206-107 771-8992/206-201 771-8992/206-202 771-8992/206-203 771-8992/206-205 771-8992/206-207 771-8992/206-301 771-8992/206-302 771-8992/206-303 771-8992/206-305 771-8992/206-307 771-8992/206-401 771-8992/206-402 771-8992/206-403 771-8992/206-405 771-8992/206-407 771-8992/206-501 771-8992/206-502 771-8992/206-503 771-8992/206-505 771-8992/206-507 771-8992/206-601 771-8992/206-602 771-8992/206-603 771-8992/206-605 771-8992/206-607 771-8992/206-701 771-8992/206-702 771-8992/206-703 771-8992/206-705 771-8992/206-707 771-8992/206-801 771-8992/206-802 771-8992/206-803 771-8992/206-805 771-8992/206-807 771-8992/207-101 771-8992/207-102 771-8992/207-201 771-8992/207-202 771-8992/207-301 771-8992/207-302 771-8992/207-401 771-8992/207-402 771-8992/207-501 771-8992/207-502 771-8992/207-601 771-8992/207-602 771-8992/207-701 771-8992/207-702 771-8992/207-801 771-8992/207-802 771-8992/216-101 771-8992/216-102 771-8992/216-201 771-8992/216-202 771-8992/216-301 771-8992/216-302 771-8992/216-401 771-8992/216-402
7718992/206307, 771 8992/206 307
