Datasheet Wago 771-9295/017-701 — Даташит
предв. собранный межблочный кабель; B2ca; Розетка - штекер; 5-пол.; Код. A; H05Z1Z1-F 5G 1,5 мм²; 7 m
| 771-9295/217-701 Wago | по запросу | ||
| Coding | A |
| Цвет | black |
| Color of sheathed cable | black |
| Connection type | Socket - Plug |
| Connector color | black |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 2.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 11.2 … 13.9 mm |
| Fire load | 0.358 MJ |
| GTIN | 4055143664547 |
| Ground function | with preceding GND contact |
| Halogen-free | Yes |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ L1 L2 L3 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Packaging type | not packed |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | N ⏚ L1 L2 L3 |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 20 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | B2ca |
| Retention force of a plug-in connection | when locked: > 80N |
| Strain relief color | black |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 7 m |
| Total number of potentials | 5 |
| Type of cable | H05Z1Z1-F 5G2.5 |
| Type of cable assembly | Interconnecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 1756.89 г |
Серия: 771 (100 из 3186)
- 771-9294/015-603 771-9294/015-605 771-9294/015-607 771-9294/015-703 771-9294/015-705 771-9294/015-707 771-9294/015-803 771-9294/015-805 771-9294/015-807 771-9294/016-101 771-9294/016-102 771-9294/016-201 771-9294/016-202 771-9294/016-301 771-9294/016-302 771-9294/016-401 771-9294/016-402 771-9294/016-502 771-9294/016-602 771-9294/016-702 771-9294/016-802 771-9294/115-205 771-9294/115-207 771-9294/115-405 771-9294/115-407 771-9294/115-605 771-9294/115-607 771-9294/115-805 771-9294/115-807 771-9294/215-403 771-9294/215-603 771-9294/215-803 771-9294/216-101 771-9294/216-201 771-9294/216-301 771-9294/216-401 771-9295/016-101 771-9295/016-201 771-9295/016-301 771-9295/016-401 771-9295/016-501 771-9295/016-601 771-9295/016-701 771-9295/016-801 771-9295/017-101 771-9295/017-201 771-9295/017-301 771-9295/017-401 771-9295/017-501 771-9295/017-601 771-9295/017-701 771-9295/017-801 771-9295/116-101 771-9295/116-201 771-9295/116-301 771-9295/116-401 771-9295/116-501 771-9295/116-601 771-9295/116-701 771-9295/116-801 771-9295/117-101 771-9295/117-201 771-9295/117-301 771-9295/117-401 771-9295/117-501 771-9295/117-601 771-9295/117-701 771-9295/117-801 771-9295/216-101 771-9295/216-201 771-9295/216-301 771-9295/216-401 771-9295/216-501 771-9295/216-601 771-9295/216-701 771-9295/216-801 771-9295/217-101 771-9295/217-201 771-9295/217-301 771-9295/217-401 771-9295/217-501 771-9295/217-601 771-9295/217-701 771-9295/217-801 771-9385/066-101 771-9385/066-201 771-9385/066-301 771-9385/066-401 771-9385/066-501 771-9385/066-601 771-9385/066-701 771-9385/066-801 771-9385/067-101 771-9385/067-201 771-9385/067-301 771-9385/067-401 771-9385/067-501 771-9385/067-601 771-9385/067-701 771-9385/067-801
7719295/017701, 771 9295/017 701
