Datasheet Wago 771-9385/066-601 — Даташит
предварительно собранный соединительный кабель; Cca; розетка/вилка; 5-полюсная; Код I; H05Z1Z1-F 5G 1,5 мм²; 6 м
| Coding | I |
| Цвет | blue |
| Color of sheathed cable | black |
| Connection type | Socket - Plug |
| Connector color | blue |
| Contact material | Copper or copper alloy, surface-treated |
| Continuous operating temperature | −35 … +85 °C |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 9.3 … 11.6 mm |
| GTIN | 4055143817868 |
| Ground function | with preceding GND contact |
| Halogen-free | Yes |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ L DA- DA+ |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Note on Continuous Service Temperature | PVC cable for temperatures ≤ 70 °C (including halogen-free)Insulating parts for temperatures ≤ 105 °C |
| Note on Protection Type | Only in mated condition with strain relief housing (These compact connectors are not designed for use in open, easily accessible areas) |
| Number of Poles | 5 |
| Packaging type | not packed |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | N ⏚ L DA- DA+ |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Processing temperature | -5 … +40 °C |
| Rated current | 16 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | Cca |
| Retention force of a plug-in connection | when locked: > 80N |
| Strain relief color | black |
| Total length | 6 m |
| Total number of potentials | 5 |
| Type of cable | H05Z1Z1-F 5G1.5 |
| Type of cable assembly | Interconnecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 999.265 г |
Серия: 771 (100 из 3186)
- 771-9295/016-401 771-9295/016-501 771-9295/016-601 771-9295/016-701 771-9295/016-801 771-9295/017-101 771-9295/017-201 771-9295/017-301 771-9295/017-401 771-9295/017-501 771-9295/017-601 771-9295/017-701 771-9295/017-801 771-9295/116-101 771-9295/116-201 771-9295/116-301 771-9295/116-401 771-9295/116-501 771-9295/116-601 771-9295/116-701 771-9295/116-801 771-9295/117-101 771-9295/117-201 771-9295/117-301 771-9295/117-401 771-9295/117-501 771-9295/117-601 771-9295/117-701 771-9295/117-801 771-9295/216-101 771-9295/216-201 771-9295/216-301 771-9295/216-401 771-9295/216-501 771-9295/216-601 771-9295/216-701 771-9295/216-801 771-9295/217-101 771-9295/217-201 771-9295/217-301 771-9295/217-401 771-9295/217-501 771-9295/217-601 771-9295/217-701 771-9295/217-801 771-9385/066-101 771-9385/066-201 771-9385/066-301 771-9385/066-401 771-9385/066-501 771-9385/066-601 771-9385/066-701 771-9385/066-801 771-9385/067-101 771-9385/067-201 771-9385/067-301 771-9385/067-401 771-9385/067-501 771-9385/067-601 771-9385/067-701 771-9385/067-801 771-9385/266-101 771-9385/266-201 771-9385/266-301 771-9385/266-401 771-9385/266-501 771-9385/266-601 771-9385/266-701 771-9385/266-801 771-9393/166-101 771-9935/006-107/080-000 771-9935/006-207/080-000 771-9935/006-307/080-000 771-9935/006-507/080-000 771-9935/006-707/080-000 771-9935/106-107/080-000 771-9935/106-307/080-000 771-9935/106-507/080-000 771-9935/106-707/080-000 771-9935/206-307/080-000 771-9935/206-507/080-000 771-9935/206-707/080-000 771-9973/006-101 771-9973/006-102 771-9973/006-105 771-9973/006-201 771-9973/006-202 771-9973/006-205 771-9973/006-301 771-9973/006-302 771-9973/006-305 771-9973/006-401 771-9973/006-402 771-9973/006-405 771-9973/006-501 771-9973/006-502 771-9973/006-505 771-9973/006-601 771-9973/006-602 771-9973/006-605
7719385/066601, 771 9385/066 601
