Линейка продуктов KEEN SIDE
Datasheet Wago 771-9385/266-201 — Даташит
Серия771
Модель771-9385/266-201
предварительно собранный соединительный кабель; Cca; вилка/открытый конец; 5-полюсный; Код I; H05Z1Z1-F 5G 1,5 мм²; 2 м
CodingI
Цветblue
Color of sheathed cableblack
Connection typePlug - free end
Connector colorblue
Continuous operating temperature−35 … +85 °C
Country of originDE
Degree of protectionIP20
Durchmesser der Mantelleitung9.3 … 11.6 mm
GTIN4055143817721
Halogen-freeYes
Locking leverнет
MarkingN ⏚ L DA- DA+
Mismating protectionYes
Note on Continuous Service TemperaturePVC cable for temperatures ≤ 70 °C (including halogen-free)Insulating parts for temperatures ≤ 105 °C
Note on Protection TypeOnly in mated condition with strain relief housing (These compact connectors are not designed for use in open, easily accessible areas)
Number of Poles5
Packaging typenot packed
Pin spacing10 mm (0.394 inch)
Potential markingN ⏚ L DA- DA+
Printing color of mating facewhite
Printing color of sheathed cablewhite
Processing temperature-5 … +40 °C
Rated current16 A
Rated voltage (III / 3)400 В
Reaction to fire class per EN 50575Cca
Strain relief colorblack
Strip length55 мм
Total length2 m
Total number of potentials5
Type of cableH05Z1Z1-F 5G1.5
Вес340.275 г
Серия: 771 (100 из 3186)
7719385/266201, 771 9385/266 201
На английском языке: Datasheet Wago 771-9385/266-201
