Datasheet Wago 771-9385/266-701 — Даташит
предварительно собранный соединительный кабель; Cca; вилка/открытый конец; 5-полюсный; Код I; H05Z1Z1-F 5G 1,5 мм²; 7 м
Coding | I |
Цвет | blue |
Color of sheathed cable | black |
Conductor preparation | tip-bonded |
Connection type | Plug - free end |
Connector color | blue |
Contact material | Copper or copper alloy, surface-treated |
Continuous operating temperature | −35 … +85 °C |
Country of origin | DE |
Cross section of single conductor | 1.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 9.3 … 11.6 mm |
GTIN | 4055143817899 |
Ground function | with preceding GND contact |
Halogen-free | Yes |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | N ⏚ L DA- DA+ |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Note on Continuous Service Temperature | PVC cable for temperatures ≤ 70 °C (including halogen-free)Insulating parts for temperatures ≤ 105 °C |
Note on Protection Type | Only in mated condition with strain relief housing (These compact connectors are not designed for use in open, easily accessible areas) |
Number of Poles | 5 |
Packaging type | not packed |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | N ⏚ L DA- DA+ |
Printing color of mating face | white |
Printing color of sheathed cable | white |
Printing color of strain relief | white |
Processing temperature | -5 … +40 °C |
Rated current | 16 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Reaction to fire class per EN 50575 | Cca |
Retention force of a plug-in connection | when locked: > 80N |
Strain relief color | black |
Strip length | 55 мм |
Total length | 7 m |
Total number of potentials | 5 |
Type of cable | H05Z1Z1-F 5G1.5 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 1140.275 г |
Серия: 771 (100 из 3186)
- 771-9295/116-501 771-9295/116-601 771-9295/116-701 771-9295/116-801 771-9295/117-101 771-9295/117-201 771-9295/117-301 771-9295/117-401 771-9295/117-501 771-9295/117-601 771-9295/117-701 771-9295/117-801 771-9295/216-101 771-9295/216-201 771-9295/216-301 771-9295/216-401 771-9295/216-501 771-9295/216-601 771-9295/216-701 771-9295/216-801 771-9295/217-101 771-9295/217-201 771-9295/217-301 771-9295/217-401 771-9295/217-501 771-9295/217-601 771-9295/217-701 771-9295/217-801 771-9385/066-101 771-9385/066-201 771-9385/066-301 771-9385/066-401 771-9385/066-501 771-9385/066-601 771-9385/066-701 771-9385/066-801 771-9385/067-101 771-9385/067-201 771-9385/067-301 771-9385/067-401 771-9385/067-501 771-9385/067-601 771-9385/067-701 771-9385/067-801 771-9385/266-101 771-9385/266-201 771-9385/266-301 771-9385/266-401 771-9385/266-501 771-9385/266-601 771-9385/266-701 771-9385/266-801 771-9393/166-101 771-9935/006-107/080-000 771-9935/006-207/080-000 771-9935/006-307/080-000 771-9935/006-507/080-000 771-9935/006-707/080-000 771-9935/106-107/080-000 771-9935/106-307/080-000 771-9935/106-507/080-000 771-9935/106-707/080-000 771-9935/206-307/080-000 771-9935/206-507/080-000 771-9935/206-707/080-000 771-9973/006-101 771-9973/006-102 771-9973/006-105 771-9973/006-201 771-9973/006-202 771-9973/006-205 771-9973/006-301 771-9973/006-302 771-9973/006-305 771-9973/006-401 771-9973/006-402 771-9973/006-405 771-9973/006-501 771-9973/006-502 771-9973/006-505 771-9973/006-601 771-9973/006-602 771-9973/006-605 771-9973/006-701 771-9973/006-702 771-9973/006-705 771-9973/006-801 771-9973/006-802 771-9973/006-805 771-9973/007-101 771-9973/007-102 771-9973/007-201 771-9973/007-202 771-9973/007-301 771-9973/007-302 771-9973/007-401 771-9973/007-402 771-9973/007-501 771-9973/007-502 771-9973/007-601
7719385/266701, 771 9385/266 701
