Datasheet Wago 771-9973/006-201 — Даташит
предв. собранный межблочный кабель; Eca; Розетка - штекер; 3-пол.; Код. P; H05VV-F 3G 1,5 мм²; 2 м
| 771-9973/017-501 Wago | по запросу | ||
| Coding | P |
| Цвет | red |
| Color of sheathed cable | black |
| Connection type | Socket - Plug |
| Connector color | red |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 7.4 … 9.4 mm |
| Fire load | 4.341 MJ |
| GTIN | 4045454401733 |
| Ground function | with preceding GND contact |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | L ⏚ N |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 3 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | L ⏚ N |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 2 m |
| Total number of potentials | 3 |
| Type of cable | H05VV-F 3G1.5 |
| Type of cable assembly | Interconnecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 232.245 г |
Серия: 771 (100 из 3186)
- 771-9295/216-701 771-9295/216-801 771-9295/217-101 771-9295/217-201 771-9295/217-301 771-9295/217-401 771-9295/217-501 771-9295/217-601 771-9295/217-701 771-9295/217-801 771-9385/066-101 771-9385/066-201 771-9385/066-301 771-9385/066-401 771-9385/066-501 771-9385/066-601 771-9385/066-701 771-9385/066-801 771-9385/067-101 771-9385/067-201 771-9385/067-301 771-9385/067-401 771-9385/067-501 771-9385/067-601 771-9385/067-701 771-9385/067-801 771-9385/266-101 771-9385/266-201 771-9385/266-301 771-9385/266-401 771-9385/266-501 771-9385/266-601 771-9385/266-701 771-9385/266-801 771-9393/166-101 771-9935/006-107/080-000 771-9935/006-207/080-000 771-9935/006-307/080-000 771-9935/006-507/080-000 771-9935/006-707/080-000 771-9935/106-107/080-000 771-9935/106-307/080-000 771-9935/106-507/080-000 771-9935/106-707/080-000 771-9935/206-307/080-000 771-9935/206-507/080-000 771-9935/206-707/080-000 771-9973/006-101 771-9973/006-102 771-9973/006-105 771-9973/006-201 771-9973/006-202 771-9973/006-205 771-9973/006-301 771-9973/006-302 771-9973/006-305 771-9973/006-401 771-9973/006-402 771-9973/006-405 771-9973/006-501 771-9973/006-502 771-9973/006-505 771-9973/006-601 771-9973/006-602 771-9973/006-605 771-9973/006-701 771-9973/006-702 771-9973/006-705 771-9973/006-801 771-9973/006-802 771-9973/006-805 771-9973/007-101 771-9973/007-102 771-9973/007-201 771-9973/007-202 771-9973/007-301 771-9973/007-302 771-9973/007-401 771-9973/007-402 771-9973/007-501 771-9973/007-502 771-9973/007-601 771-9973/007-602 771-9973/007-701 771-9973/007-702 771-9973/007-801 771-9973/007-802 771-9973/016-101 771-9973/016-102 771-9973/016-105 771-9973/016-201 771-9973/016-202 771-9973/016-205 771-9973/016-301 771-9973/016-302 771-9973/016-305 771-9973/016-401 771-9973/016-402 771-9973/016-405 771-9973/016-501
7719973/006201, 771 9973/006 201
