Datasheet Wago 771-9973/206-101 — Даташит
предв. собранный соединительный кабель; Eca; Штекер/открытый; 3-пол.; Код. P; H05VV-F 3G 1,5 мм²; 1 м
771-9973/206-704 Wago | по запросу |
Coding | P |
Цвет | red |
Color of sheathed cable | black |
Conductor preparation | tip-bonded |
Connection type | Plug - free end |
Connector color | red |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Cross section of single conductor | 1.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 7.4 … 9.4 mm |
Fire load | 2.186 MJ |
GTIN | 4045454403157 |
Ground function | with preceding GND contact |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | L ⏚ N |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 3 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | L ⏚ N |
Printing color of mating face | white |
Printing color of sheathed cable | white |
Printing color of strain relief | white |
Rated current | 16 A |
Rated voltage (III / 3) | 250 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | black |
Strip length | 55 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 1 m |
Total number of potentials | 3 |
Type of cable | H05VV-F 3G1.5 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 106.79 г |
Серия: 771 (100 из 3186)
- 771-9973/106-801 771-9973/106-802 771-9973/107-101 771-9973/107-102 771-9973/107-201 771-9973/107-202 771-9973/107-301 771-9973/107-302 771-9973/107-401 771-9973/107-402 771-9973/107-501 771-9973/107-502 771-9973/107-601 771-9973/107-602 771-9973/107-701 771-9973/107-702 771-9973/107-801 771-9973/107-802 771-9973/116-101 771-9973/116-102 771-9973/116-201 771-9973/116-202 771-9973/116-301 771-9973/116-302 771-9973/116-401 771-9973/116-402 771-9973/116-501 771-9973/116-502 771-9973/116-601 771-9973/116-602 771-9973/116-701 771-9973/116-702 771-9973/116-801 771-9973/116-802 771-9973/117-101 771-9973/117-102 771-9973/117-201 771-9973/117-202 771-9973/117-301 771-9973/117-302 771-9973/117-401 771-9973/117-402 771-9973/117-501 771-9973/117-502 771-9973/117-601 771-9973/117-602 771-9973/117-701 771-9973/117-702 771-9973/117-801 771-9973/117-802 771-9973/206-101 771-9973/206-102 771-9973/206-104 771-9973/206-105 771-9973/206-201 771-9973/206-202 771-9973/206-204 771-9973/206-205 771-9973/206-301 771-9973/206-302 771-9973/206-304 771-9973/206-305 771-9973/206-401 771-9973/206-402 771-9973/206-404 771-9973/206-405 771-9973/206-501 771-9973/206-502 771-9973/206-504 771-9973/206-505 771-9973/206-601 771-9973/206-602 771-9973/206-604 771-9973/206-605 771-9973/206-701 771-9973/206-702 771-9973/206-704 771-9973/206-705 771-9973/206-801 771-9973/206-802 771-9973/206-804 771-9973/206-805 771-9973/207-101 771-9973/207-102 771-9973/207-201 771-9973/207-202 771-9973/207-301 771-9973/207-302 771-9973/207-401 771-9973/207-402 771-9973/207-501 771-9973/207-502 771-9973/207-601 771-9973/207-602 771-9973/207-701 771-9973/207-702 771-9973/207-801 771-9973/207-802 771-9973/216-101 771-9973/216-102
7719973/206101, 771 9973/206 101
