Datasheet Wago 771-9973/216-801 — Даташит
предв. собранный соединительный кабель; Eca; Штекер/открытый; 3-пол.; Код. P; H05Z1Z1-F 3G 1,5 мм²; 8 m
| 771-9973/216-104 Wago | по запросу | ||
| Coding | P |
| Цвет | red |
| Color of sheathed cable | black |
| Conductor preparation | tip-bonded |
| Connection type | Plug - free end |
| Connector color | red |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 7.4 … 9.4 mm |
| Fire load | 12.911 MJ |
| GTIN | 4045454402631 |
| Ground function | with preceding GND contact |
| Halogen-free | Yes |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | L ⏚ N |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 3 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | L ⏚ N |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Strain relief color | black |
| Strip length | 55 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 8 m |
| Total number of potentials | 3 |
| Type of cable | H05Z1Z1-F 3G1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 774.978 г |
Серия: 771 (100 из 3186)
- 771-9973/206-704 771-9973/206-705 771-9973/206-801 771-9973/206-802 771-9973/206-804 771-9973/206-805 771-9973/207-101 771-9973/207-102 771-9973/207-201 771-9973/207-202 771-9973/207-301 771-9973/207-302 771-9973/207-401 771-9973/207-402 771-9973/207-501 771-9973/207-502 771-9973/207-601 771-9973/207-602 771-9973/207-701 771-9973/207-702 771-9973/207-801 771-9973/207-802 771-9973/216-101 771-9973/216-102 771-9973/216-104 771-9973/216-105 771-9973/216-201 771-9973/216-202 771-9973/216-204 771-9973/216-205 771-9973/216-301 771-9973/216-302 771-9973/216-304 771-9973/216-305 771-9973/216-401 771-9973/216-402 771-9973/216-404 771-9973/216-405 771-9973/216-501 771-9973/216-502 771-9973/216-504 771-9973/216-505 771-9973/216-601 771-9973/216-602 771-9973/216-604 771-9973/216-605 771-9973/216-701 771-9973/216-702 771-9973/216-704 771-9973/216-705 771-9973/216-801 771-9973/216-802 771-9973/216-804 771-9973/216-805 771-9973/217-101 771-9973/217-102 771-9973/217-201 771-9973/217-202 771-9973/217-301 771-9973/217-302 771-9973/217-401 771-9973/217-402 771-9973/217-501 771-9973/217-502 771-9973/217-601 771-9973/217-602 771-9973/217-701 771-9973/217-702 771-9973/217-801 771-9973/217-802 771-9975/006-101 771-9975/006-102 771-9975/006-201 771-9975/006-202 771-9975/006-301 771-9975/006-302 771-9975/006-401 771-9975/006-402 771-9975/006-501 771-9975/006-502 771-9975/006-601 771-9975/006-602 771-9975/006-701 771-9975/006-702 771-9975/006-801 771-9975/006-802 771-9975/007-101 771-9975/007-102 771-9975/007-201 771-9975/007-202 771-9975/007-301 771-9975/007-302 771-9975/007-401 771-9975/007-402 771-9975/007-501 771-9975/007-502 771-9975/007-601 771-9975/007-602 771-9975/007-701 771-9975/007-702
7719973/216801, 771 9973/216 801
