Datasheet Wago 771-9975/007-201 — Даташит
предв. собранный межблочный кабель; Eca; Розетка - штекер; 5-пол.; Код. P; H05VV-F 5G 2,5 мм²; 2 м
| 771-9975/116-401 Wago | по запросу | ||
| Coding | P |
| Цвет | red |
| Color of sheathed cable | black |
| Connection type | Socket - Plug |
| Connector color | red |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 2.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 11.2 … 13.9 mm |
| Fire load | 8.357 MJ |
| GTIN | 4045454433000 |
| Ground function | with preceding GND contact |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ L1 L2 L3 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | N ⏚ L1 L2 L3 |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 20 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 2 m |
| Total number of potentials | 5 |
| Type of cable | H05VV-F 5G2.5 |
| Type of cable assembly | Interconnecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 521.185 г |
Серия: 771 (100 из 3186)
- 771-9973/216-501 771-9973/216-502 771-9973/216-504 771-9973/216-505 771-9973/216-601 771-9973/216-602 771-9973/216-604 771-9973/216-605 771-9973/216-701 771-9973/216-702 771-9973/216-704 771-9973/216-705 771-9973/216-801 771-9973/216-802 771-9973/216-804 771-9973/216-805 771-9973/217-101 771-9973/217-102 771-9973/217-201 771-9973/217-202 771-9973/217-301 771-9973/217-302 771-9973/217-401 771-9973/217-402 771-9973/217-501 771-9973/217-502 771-9973/217-601 771-9973/217-602 771-9973/217-701 771-9973/217-702 771-9973/217-801 771-9973/217-802 771-9975/006-101 771-9975/006-102 771-9975/006-201 771-9975/006-202 771-9975/006-301 771-9975/006-302 771-9975/006-401 771-9975/006-402 771-9975/006-501 771-9975/006-502 771-9975/006-601 771-9975/006-602 771-9975/006-701 771-9975/006-702 771-9975/006-801 771-9975/006-802 771-9975/007-101 771-9975/007-102 771-9975/007-201 771-9975/007-202 771-9975/007-301 771-9975/007-302 771-9975/007-401 771-9975/007-402 771-9975/007-501 771-9975/007-502 771-9975/007-601 771-9975/007-602 771-9975/007-701 771-9975/007-702 771-9975/007-801 771-9975/007-802 771-9975/016-101 771-9975/016-102 771-9975/016-201 771-9975/016-202 771-9975/016-301 771-9975/016-302 771-9975/016-401 771-9975/016-402 771-9975/016-501 771-9975/016-502 771-9975/016-601 771-9975/016-602 771-9975/016-701 771-9975/016-702 771-9975/016-801 771-9975/016-802 771-9975/017-101 771-9975/017-102 771-9975/017-201 771-9975/017-202 771-9975/017-301 771-9975/017-302 771-9975/017-401 771-9975/017-402 771-9975/017-501 771-9975/017-502 771-9975/017-601 771-9975/017-602 771-9975/017-701 771-9975/017-702 771-9975/017-801 771-9975/017-802 771-9975/106-101 771-9975/106-102 771-9975/106-201 771-9975/106-202
7719975/007201, 771 9975/007 201
