Datasheet Wago 771-9975/116-101 — Даташит
предв. собранный соединительный кабель; Eca; Розетка/открытая; 5-пол.; Код. P; H05Z1Z1-F 5G 1,5 мм²; 1 м
| 771-9975/116-401 Wago | по запросу | ||
| Coding | P |
| Цвет | red |
| Color of sheathed cable | black |
| Conductor preparation | tip-bonded |
| Connection type | Socket - free end |
| Connector color | red |
| Contact material | Copper or copper alloy, surface-treated |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 9.3 … 11.6 mm |
| Fire load | 2.695 MJ |
| GTIN | 4045454406691 |
| Ground function | with preceding GND contact |
| Halogen-free | Yes |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ L1 L2 L3 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | N ⏚ L1 L2 L3 |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 16 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Strain relief color | black |
| Strip length | 55 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 1 m |
| Total number of potentials | 5 |
| Type of cable | H05Z1Z1-F 5G1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 164.877 г |
Серия: 771 (100 из 3186)
- 771-9975/016-801 771-9975/016-802 771-9975/017-101 771-9975/017-102 771-9975/017-201 771-9975/017-202 771-9975/017-301 771-9975/017-302 771-9975/017-401 771-9975/017-402 771-9975/017-501 771-9975/017-502 771-9975/017-601 771-9975/017-602 771-9975/017-701 771-9975/017-702 771-9975/017-801 771-9975/017-802 771-9975/106-101 771-9975/106-102 771-9975/106-201 771-9975/106-202 771-9975/106-301 771-9975/106-302 771-9975/106-401 771-9975/106-402 771-9975/106-501 771-9975/106-502 771-9975/106-601 771-9975/106-602 771-9975/106-701 771-9975/106-702 771-9975/106-801 771-9975/106-802 771-9975/107-101 771-9975/107-102 771-9975/107-201 771-9975/107-202 771-9975/107-301 771-9975/107-302 771-9975/107-401 771-9975/107-402 771-9975/107-501 771-9975/107-502 771-9975/107-601 771-9975/107-602 771-9975/107-701 771-9975/107-702 771-9975/107-801 771-9975/107-802 771-9975/116-101 771-9975/116-102 771-9975/116-201 771-9975/116-202 771-9975/116-301 771-9975/116-302 771-9975/116-401 771-9975/116-402 771-9975/116-501 771-9975/116-502 771-9975/116-601 771-9975/116-602 771-9975/116-701 771-9975/116-702 771-9975/116-801 771-9975/116-802 771-9975/117-101 771-9975/117-102 771-9975/117-201 771-9975/117-202 771-9975/117-301 771-9975/117-302 771-9975/117-401 771-9975/117-402 771-9975/117-501 771-9975/117-502 771-9975/117-601 771-9975/117-602 771-9975/117-701 771-9975/117-702 771-9975/117-801 771-9975/117-802 771-9975/206-101 771-9975/206-102 771-9975/206-201 771-9975/206-202 771-9975/206-301 771-9975/206-302 771-9975/206-401 771-9975/206-402 771-9975/206-501 771-9975/206-502 771-9975/206-601 771-9975/206-602 771-9975/206-701 771-9975/206-702 771-9975/206-801 771-9975/206-802 771-9975/207-101 771-9975/207-102
7719975/116101, 771 9975/116 101
