Datasheet Wago 771-9994/206-807 — Даташит
предв. собранный соединительный кабель; Eca; Штекер/открытый; 4-пол.; Код. B; Контрольный кабель 4 x 1,5 мм²; 8 m
771-9994/206-501 Wago | по запросу |
Coding | B |
Цвет | pink |
Color of sheathed cable | gray |
Conductor preparation | tip-bonded |
Connection type | Plug - free end |
Connector color | pink |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Cross section of single conductor | 1.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 8.4 … 10.5 mm |
Fire load | 2.63 MJ |
GTIN | 4055143126908 |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | 1 2 3 4 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Number of Poles | 4 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | 1 2 3 4 |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | white |
Rated current | 16 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | black |
Strip length | 55 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 8 m |
Total number of potentials | 4 |
Type of cable | Control line 4 x 1.5 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 1055.09 г |
Серия: 771 (100 из 3186)
- 771-4993/007-103 771-4993/007-105 771-4993/007-107 771-4993/007-303 771-4993/007-305 771-4993/007-307 771-4993/007-503 771-4993/007-505 771-4993/007-507 771-4993/107-103 771-4993/107-105 771-4993/107-107 771-4993/107-303 771-4993/107-305 771-4993/107-307 771-4993/107-503 771-4993/107-505 771-4993/107-507 771-4993/207-303 771-5001/100-000 771-5001/106-000 771-5001/107-000 771-5001/110-000 771-5001/131-000 771-5001/132-000 771-5001/148-000 771-5001/149-000 771-5001/150-000 771-5001/151-000 771-5001/152-000 771-5001/153-000 771-5001/154-000 771-5001/155-000 771-5001/156-000 771-5001/157-000 771-5001/158-000 771-5001/159-000 771-5001/160-000 771-5001/161-000 771-5001/162-000 771-5001/163-000 771-5001/164-000 771-5001/165-000 771-5001/166-000 771-5001/167-000 771-5001/168-000 771-5001/169-000 771-5001/170-000 771-5001/171-000 771-5001/172-000 771-5001/173-000 771-5001/174-000 771-5001/175-000 771-5001/176-000 771-5001/177-000 771-5001/178-000 771-5001/179-000 771-5001/180-000 771-5001/181-000 771-5001/182-000 771-5001/183-000 771-5001/185-000 771-5001/186-000 771-5001/189-000 771-5001/190-000 771-5001/191-000 771-5001/192-000 771-5001/193-000 771-5001/194-000 771-5001/195-000 771-5001/196-000 771-5001/197-000 771-5001/198-000 771-5001/199-000 771-5001/200-000 771-5001/201-000 771-5001/202-000 771-5001/203-000 771-5001/204-000 771-5001/205-000 771-5001/206-000 771-5001/207-000 771-5001/208-000 771-5001/209-000 771-5001/210-000 771-5001/211-000 771-5001/212-000 771-5001/213-000 771-5001/214-000 771-5001/215-000 771-5001/216-000 771-5001/217-000 771-5001/218-000 771-5001/219-000 771-5001/220-000 771-5001/221-000 771-5001/222-000 771-5001/223-000 771-5001/224-000 771-6993/006-101
7719994/206807, 771 9994/206 807
