Заказные клавиатуры Accord по вашему ТЗ
Datasheet Wago 772 — Даташит
Серия772
Datasheet Wago 772
Wago 772
Parameters / Models772-260
772-260
772-261
772-261
772-262
772-262
772-263
772-263
772-264/060-000
772-264/060-000
772-265/060-000
772-265/060-000
772-266/060-000
772-266/060-000
772-267
772-267
772-268
772-268
772-269
772-269
772-271
772-271
772-272
772-272
Actuation typeOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating tool
CodingAABBPPI
Цветblackblackblackblackgraygraygrayredredredblueblue
Connection technologyPush-in CAGE CLAMP®IDCIDCPush-in CAGE CLAMP®IDCIDCPush-in CAGE CLAMP®IDCIDCPush-in CAGE CLAMP®IDC
Connection technology 2IDC connectionIDC connectionIDC connectionIDC connection
Contact materialCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treated
Country of originDEDEDEDEDEDEDEDEDEDEDEDE
Degree of protectionIP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20
Габариты: глубина82.5 mm / 3.248 inch79 mm / 3.11 inch79 mm / 3.11 inch82.5 mm / 3.248 inch79 mm / 3.11 inch79 mm / 3.11 inch82.5 mm / 3.248 inch79 mm / 3.11 inch79 mm / 3.11 inch82.5 mm / 3.248 inch79 mm / 3.11 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG0.5 … 4 mm² / 20 … 12 AWG0.5 … 4 mm² / 20 … 12 AWG0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG0.25 … 1.5 mm² / 20 … 16 AWG0.25 … 1.5 mm² / 20 … 16 AWG0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG0.25 … 2.5 mm² / 20 … 14 AWG0.25 … 2.5 mm² / 20 … 14 AWG0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG1.5 mm² / 16 AWG1.5 mm² / 16 AWG1.5 mm² / 16 AWG
Fire load, MJ0.3462.2211.7721.8432.2211.7561.8452.2211.7621.8332.2881.847
Flammability class per UL94V0V0V0V0V0V0V0V0V0V0V0V0
GTIN404545454398340454540619994045454062002404545406201940508215857704050821585787405082158579440454545995154045454599522404545459953940551431746714055143174688
Height46.5 mm / 1.831 inch46.5 mm / 1.831 inch46.5 mm / 1.831 inch46.5 mm / 1.831 inch46.5 mm / 1.831 inch46.5 mm / 1.831 inch46.5 mm / 1.831 inch46.5 mm / 1.831 inch46.5 mm / 1.831 inch46.5 mm / 1.831 inch46.5 mm / 1.831 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Locking of plug-in connectionlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking lever
MarkingN ⏚ L1 L2 L3N ⏚ L1 L2 L3L ⏚ NN ⏚ L1 L2 L3N ⏚ L1 L2 L3L ⏚ NN ⏚ L1 L2 L3N ⏚ L1 L2 L3L ⏚ NN ⏚ L DA- DA+N ⏚ L DA- DA+
Mating force of a plug-in connectionapprox. 30–70N (depending on number of poles)approx. 30–70N (depending on number of poles)approx. 30–70N (depending on number of poles)approx. 30–70N (depending on number of poles)approx. 30–70N (depending on number of poles)approx. 30–70N (depending on number of poles)approx. 30–70N (depending on number of poles)approx. 30–70N (depending on number of poles)approx. 30–70N (depending on number of poles)approx. 30–70N (depending on number of poles)approx. 30–70N (depending on number of poles)
Mismating protectionYesYesYesYesYesYesYesYesYesYesYes
Mounting typeScrew mounting
Nominal cross section4 mm²4 mm²4 mm²4 mm²
Number of Poles55355355355
Packaging typenot packednot packed
Potential markingN ⏚ L1 L2 L3N ⏚ L1 L2 L3L ⏚ NN ⏚ L1 L2 L3N ⏚ L1 L2 L3L ⏚ NN ⏚ L1 L2 L3N ⏚ L1 L2 L3L ⏚ NN ⏚ L DA- DA+N ⏚ L DA- DA+
Product Group20 (WINSTA)20 (WINSTA)20 (WINSTA)20 (WINSTA)20 (WINSTA)20 (WINSTA)20 (WINSTA)20 (WINSTA)20 (WINSTA)
Rated current, A2525252525252525252525
Rated impulse voltage (III / 3), kV66666666666
Rated voltage (III / 3), В400400400400400400400400400400400
Solid conductor0.5 … 4 mm² / 20 … 12 AWG0.5 … 4 mm² / 20 … 12 AWG0.5 … 4 mm² / 20 … 12 AWG0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG1.5 … 4 mm² / 16 … 12 AWG1.5 … 4 mm² / 16 … 12 AWG1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch9 mm / 0.35 Inch9 mm / 0.35 Inch9 mm / 0.35 Inch
Surrounding air (operating) temperature-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C
Total number of connection points10101010
Total number of potentials55355355355
Unmating force of a plug-in connectionwhen unlocked: approx. 15–20Nwhen unlocked: approx. 15–20Nwhen unlocked: approx. 15–20Nwhen unlocked: approx. 15–20Nwhen unlocked: approx. 15–20Nwhen unlocked: approx. 15–20Nwhen unlocked: approx. 15–20Nwhen unlocked: approx. 15–20Nwhen unlocked: approx. 15–20Nwhen unlocked: approx. 15–20Nwhen unlocked: approx. 15–20N
Вес, г11.695.01376.35570.05294.95375.8270.12794.95376.02569.72294.95382
Ширина50 mm / 1.969 inch50 mm / 1.969 inch49 mm / 1.929 inch50 mm / 1.969 inch50 mm / 1.969 inch49 mm / 1.929 inch50 mm / 1.969 inch50 mm / 1.969 inch49 mm / 1.929 inch50 mm / 1.969 inch50 mm / 1.969 inch
На английском языке: Datasheet Wago 772
Политика конфиденциальности
