Datasheet Wago 774-9973/106-105 — Даташит
предв. собранный соединительный кабель; Eca; Розетка/открытая; 3-пол.; Код. S; H05VV-F 3 x 1,5 мм²; 1 м
| 774-9973/006-405 Wago | по запросу | ||
| Coding | S |
| Цвет | brown |
| Conductor preparation | tip-bonded |
| Connection type | Socket - free end |
| Connector color | brown |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 7.4 … 9.4 mm |
| Fire load | 2.018 MJ |
| GTIN | 4050821489610 |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Marking | 1 2 L |
| Mating force of a plug-in connection | approx. 30 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 3 |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 100 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 1 m |
| Total number of potentials | 3 |
| Type of cable | H05VV-F 3x1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 30 … 70 N (depending on pole number) |
| Вес | 111.28 г |
Серия: 774 (100 из 386)
- 774-1373/9900-000 774-213/9900-000 774-9273/1516-105 774-9273/1516-205 774-9273/1516-305 774-9273/1516-405 774-9273/1516-505 774-9273/1516-605 774-9273/1516-805 774-9293/1517-701 774-9293/1517-801 774-9373/1566-105 774-9373/1566-205 774-9373/1566-305 774-9373/1566-405 774-9373/1566-505 774-9373/1566-605 774-9373/1566-805 774-9973/006-105 774-9973/006-205 774-9973/006-305 774-9973/006-405 774-9973/006-505 774-9973/006-605 774-9973/006-705 774-9973/006-805 774-9973/016-105 774-9973/016-205 774-9973/016-305 774-9973/016-405 774-9973/016-505 774-9973/016-605 774-9973/016-705 774-9973/016-805 774-9973/106-105 774-9973/106-205 774-9973/106-305 774-9973/106-405 774-9973/106-505 774-9973/106-605 774-9973/106-705 774-9973/106-805 774-9973/116-105 774-9973/116-205 774-9973/116-305 774-9973/116-405 774-9973/116-505 774-9973/116-605 774-9973/116-705 774-9973/116-805 774-9973/1506-105 774-9973/1506-205 774-9973/1506-305 774-9973/1506-405 774-9973/1506-505 774-9973/1506-605 774-9973/1506-705 774-9973/1506-805 774-9973/1516-105 774-9973/1516-205 774-9973/1516-305 774-9973/1516-405 774-9973/1516-505 774-9973/1516-605 774-9973/1516-705 774-9973/1516-805 774-9973/206-105 774-9973/206-205 774-9973/206-305 774-9973/206-405 774-9973/206-505 774-9973/206-605 774-9973/206-705 774-9973/206-805 774-9973/216-105 774-9973/216-205 774-9973/216-305 774-9973/216-405 774-9973/216-505 774-9973/216-605 774-9973/216-705 774-9973/216-805 774-9993/006-101 774-9993/006-102 774-9993/006-201 774-9993/006-202 774-9993/006-301 774-9993/006-302 774-9993/006-401 774-9993/006-402 774-9993/006-501 774-9993/006-502 774-9993/006-601 774-9993/006-602 774-9993/006-701 774-9993/006-702 774-9993/006-801 774-9993/006-802 774-9993/007-101 774-9993/007-102
7749973/106105, 774 9973/106 105
