Datasheet Wago 774-9993/107-302 — Даташит
предв. собранный соединительный кабель; Eca; Розетка/открытая; 3-пол.; Код. A; H05VV-F 3G 2,5 мм²; 3 м
| 774-9993/107-502 Wago | по запросу | ||
| Цвет | white |
| Conductor preparation | tip-bonded |
| Connection type | Socket - free end |
| Connector color | white |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 2.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 9.2 … 11.4 mm |
| Fire load | 8.059 MJ |
| GTIN | 4045454322908 |
| Ground function | with preceding GND contact |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Marking | L ⏚ N |
| Mating force of a plug-in connection | approx. 30 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 3 |
| Rated current | 20 A |
| Rated voltage (III / 3) | 250 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | white |
| Strip length | 55 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 3 m |
| Total number of potentials | 3 |
| Type of cable | H05VV-F 3G2.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 30 … 70 N (depending on pole number) |
| Вес | 485.023 г |
Серия: 774 (100 из 386)
- 774-9993/016-202 774-9993/016-301 774-9993/016-302 774-9993/016-401 774-9993/016-402 774-9993/016-501 774-9993/016-502 774-9993/016-601 774-9993/016-602 774-9993/016-701 774-9993/016-702 774-9993/016-801 774-9993/016-802 774-9993/017-101 774-9993/017-102 774-9993/017-201 774-9993/017-202 774-9993/017-301 774-9993/017-302 774-9993/017-401 774-9993/017-402 774-9993/017-501 774-9993/017-502 774-9993/017-601 774-9993/017-602 774-9993/017-701 774-9993/017-702 774-9993/017-801 774-9993/017-802 774-9993/106-101 774-9993/106-102 774-9993/106-201 774-9993/106-202 774-9993/106-301 774-9993/106-302 774-9993/106-401 774-9993/106-402 774-9993/106-501 774-9993/106-502 774-9993/106-601 774-9993/106-602 774-9993/106-701 774-9993/106-702 774-9993/106-801 774-9993/106-802 774-9993/107-101 774-9993/107-102 774-9993/107-201 774-9993/107-202 774-9993/107-301 774-9993/107-302 774-9993/107-401 774-9993/107-402 774-9993/107-501 774-9993/107-502 774-9993/107-601 774-9993/107-602 774-9993/107-701 774-9993/107-702 774-9993/107-801 774-9993/107-802 774-9993/116-101 774-9993/116-102 774-9993/116-201 774-9993/116-202 774-9993/116-301 774-9993/116-302 774-9993/116-401 774-9993/116-402 774-9993/116-501 774-9993/116-502 774-9993/116-601 774-9993/116-602 774-9993/116-701 774-9993/116-702 774-9993/116-801 774-9993/116-802 774-9993/117-101 774-9993/117-102 774-9993/117-201 774-9993/117-202 774-9993/117-301 774-9993/117-302 774-9993/117-401 774-9993/117-402 774-9993/117-501 774-9993/117-502 774-9993/117-601 774-9993/117-602 774-9993/117-701 774-9993/117-702 774-9993/117-801 774-9993/117-802 774-9993/1507-101 774-9993/1507-201 774-9993/1507-301 774-9993/1507-401 774-9993/1507-501 774-9993/1507-601 774-9993/1507-701
7749993/107302, 774 9993/107 302
