Datasheet Wago 774-9993/206-202 — Даташит
предв. собранный соединительный кабель; Eca; Штекер/открытый; 3-пол.; Код. A; H05VV-F 3G 1,5 мм²; 2 м
| 774-9993/206-602 Wago | по запросу | ||
| Цвет | white |
| Conductor preparation | tip-bonded |
| Connection type | Plug - free end |
| Connector color | white |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 7.4 … 9.4 mm |
| Fire load | 3.927 MJ |
| GTIN | 4045454323417 |
| Ground function | with preceding GND contact |
| Locking of plug-in connection | locking lever |
| Marking | L ⏚ N |
| Mating force of a plug-in connection | approx. 30 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 3 |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | white |
| Strip length | 55 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 2 m |
| Total number of potentials | 3 |
| Type of cable | H05VV-F 3G1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 30 … 70 N (depending on pole number) |
| Вес | 216.983 г |
Серия: 774 (100 из 386)
- 774-9993/116-102 774-9993/116-201 774-9993/116-202 774-9993/116-301 774-9993/116-302 774-9993/116-401 774-9993/116-402 774-9993/116-501 774-9993/116-502 774-9993/116-601 774-9993/116-602 774-9993/116-701 774-9993/116-702 774-9993/116-801 774-9993/116-802 774-9993/117-101 774-9993/117-102 774-9993/117-201 774-9993/117-202 774-9993/117-301 774-9993/117-302 774-9993/117-401 774-9993/117-402 774-9993/117-501 774-9993/117-502 774-9993/117-601 774-9993/117-602 774-9993/117-701 774-9993/117-702 774-9993/117-801 774-9993/117-802 774-9993/1507-101 774-9993/1507-201 774-9993/1507-301 774-9993/1507-401 774-9993/1507-501 774-9993/1507-601 774-9993/1507-701 774-9993/1507-801 774-9993/1517-101 774-9993/1517-201 774-9993/1517-301 774-9993/1517-401 774-9993/1517-501 774-9993/1517-601 774-9993/1517-701 774-9993/1517-801 774-9993/206-101 774-9993/206-102 774-9993/206-201 774-9993/206-202 774-9993/206-301 774-9993/206-302 774-9993/206-401 774-9993/206-402 774-9993/206-501 774-9993/206-502 774-9993/206-601 774-9993/206-602 774-9993/206-701 774-9993/206-702 774-9993/206-801 774-9993/206-802 774-9993/207-101 774-9993/207-102 774-9993/207-201 774-9993/207-202 774-9993/207-301 774-9993/207-302 774-9993/207-401 774-9993/207-402 774-9993/207-501 774-9993/207-502 774-9993/207-601 774-9993/207-602 774-9993/207-701 774-9993/207-702 774-9993/207-801 774-9993/207-802 774-9993/216-101 774-9993/216-102 774-9993/216-201 774-9993/216-202 774-9993/216-301 774-9993/216-302 774-9993/216-401 774-9993/216-402 774-9993/216-501 774-9993/216-502 774-9993/216-601 774-9993/216-602 774-9993/216-701 774-9993/216-702 774-9993/216-801 774-9993/216-802 774-9993/217-101 774-9993/217-102 774-9993/217-201 774-9993/217-202 774-9993/217-301
7749993/206202, 774 9993/206 202
