Datasheet Wago 774-9994/106-701 — Даташит
предв. собранный соединительный кабель; Eca; Розетка/открытая; 4-пол.; Код. A; H05VV-F 4G 1,5 мм²; 7 m
| 774-9994/106-201 Wago | по запросу | ||
| Coding | A |
| Цвет | black |
| Conductor preparation | tip-bonded |
| Connection type | Socket - free end |
| Connector color | black |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 8.4 … 10.5 mm |
| Fire load | 15.229 MJ |
| GTIN | 4045454345921 |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ 2 1 |
| Mating force of a plug-in connection | approx. 30 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 4 |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 55 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 7 m |
| Total number of potentials | 4 |
| Type of cable | H05VV-F 4G1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 30 … 70 N (depending on pole number) |
| Вес | 915.128 г |
Серия: 774 (100 из 386)
- 774-9993/217-601 774-9993/217-602 774-9993/217-701 774-9993/217-702 774-9993/217-801 774-9993/217-802 774-9994/006-101 774-9994/006-102 774-9994/006-201 774-9994/006-202 774-9994/006-301 774-9994/006-302 774-9994/006-401 774-9994/006-402 774-9994/006-501 774-9994/006-502 774-9994/006-601 774-9994/006-602 774-9994/006-701 774-9994/006-702 774-9994/006-801 774-9994/006-802 774-9994/016-101 774-9994/016-102 774-9994/016-201 774-9994/016-202 774-9994/016-301 774-9994/016-302 774-9994/016-401 774-9994/016-402 774-9994/016-501 774-9994/016-502 774-9994/016-601 774-9994/016-602 774-9994/016-701 774-9994/016-702 774-9994/016-801 774-9994/016-802 774-9994/106-101 774-9994/106-102 774-9994/106-201 774-9994/106-202 774-9994/106-301 774-9994/106-302 774-9994/106-401 774-9994/106-402 774-9994/106-501 774-9994/106-502 774-9994/106-601 774-9994/106-602 774-9994/106-701 774-9994/106-702 774-9994/106-801 774-9994/106-802 774-9994/116-101 774-9994/116-102 774-9994/116-201 774-9994/116-202 774-9994/116-301 774-9994/116-302 774-9994/116-401 774-9994/116-402 774-9994/116-501 774-9994/116-502 774-9994/116-601 774-9994/116-602 774-9994/116-701 774-9994/116-702 774-9994/116-801 774-9994/116-802 774-9994/206-101 774-9994/206-102 774-9994/206-201 774-9994/206-202 774-9994/206-301 774-9994/206-302 774-9994/206-401 774-9994/206-402 774-9994/206-501 774-9994/206-502 774-9994/206-601 774-9994/206-602 774-9994/206-701 774-9994/206-702 774-9994/206-801 774-9994/206-802 774-9994/216-101 774-9994/216-102 774-9994/216-201 774-9994/216-202 774-9994/216-301 774-9994/216-302 774-9994/216-401 774-9994/216-402 774-9994/216-501 774-9994/216-502 774-9994/216-601 774-9994/216-602 774-9994/216-701 774-9994/216-702
7749994/106701, 774 9994/106 701
