Оптопары и оптореле Megawin
Datasheet Wago 831-3205/1020-004 — Даташит
Серия831
Модель831-3205/1020-004
Штекер; с корпусом разгрузки натяжения; 5-пол.; Кодирование А; 1-проводное соединение
831-3205/1020-004
Actuation typeOperating tool Push-in
CodingA
Цветblack
Connectable sheathed cable diameter13 … 18 mm
Country of originDE
Degree of protectionIP20
Габариты: глубина46 mm / 1.811 inch
Fine-stranded conductor0.5 … 6 mm² / 20 … 8 AWG
GTIN4055143500746
Height27.55 mm / 1.085 inch
Locking leverнет
MarkingL1 N ⏚ L2 L3
Mating force of a plug-in connectionapprox. 30–70N (depending on number of poles)
Mismating protectionYes
Nominal cross section6 mm²
Note (strip length)see also packaging or instructions
Number of Poles5
Pin spacing7.62 mm (0.3 inch)
Potential markingL1 N ⏚ L2 L3
Rated current35 A
Rated voltage (III / 3)400 В
Solid conductor0.5 … 6 mm² / 20 … 8 AWG
Strain reliefStrain relief housing
Stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Strip length13 mm / 0.51 Inch
Total number of connection points5
Total number of potentials5
Unmating force of a plug-in connectionwhen unlocked: approx. 30–70N (depending on number of poles)
Вес69.105 г
Ширина48 mm / 1.89 inch
8313205/1020004, 831 3205/1020 004
На английском языке: Datasheet Wago 831-3205/1020-004
