Datasheet Wago 831-3205/1020-050 — Даташит
Штекер; с корпусом разгрузки натяжения; 5-пол.; Кодирование А; 1-проводное соединение
PLUG; WITH STRAIN RELIEF HOUSING | |||
| 831-3205/1020-004 Wago | по запросу | ||
| Actuation type | Operating tool Push-in |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Coding | A |
| Цвет | white |
| Connectable sheathed cable diameter | 13 … 18 mm |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper or copper alloy, surface-treated |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Degree of protection | IP20 |
| Габариты: глубина | 46 mm / 1.811 inch |
| Fine-stranded conductor | 0.5 … 6 mm² / 20 … 8 AWG |
| GTIN | 4055143500722 |
| Height | 27.55 mm / 1.085 inch |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | L1 N ⏚ L2 L3 |
| Mating force of a plug-in connection | approx. 30–70N (depending on number of poles) |
| Mismating protection | Yes |
| Nominal cross section | 6 mm² |
| Note (strip length) | see also packaging or instructions |
| Number of Poles | 5 |
| Pin spacing | 7.62 mm (0.3 inch) |
| Potential marking | L1 N ⏚ L2 L3 |
| Rated current | 35 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Solid conductor | 0.5 … 6 mm² / 20 … 8 AWG |
| Strain relief | Strain relief housing |
| Stranded conductor | 0.5 … 4 mm² / 20 … 12 AWG |
| Strip length | 13 mm / 0.51 Inch |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total number of connection points | 5 |
| Total number of potentials | 5 |
| Unmating force of a plug-in connection | when unlocked: approx. 30–70N (depending on number of poles) |
| Вес | 66.955 г |
| Ширина | 48 mm / 1.89 inch |
Серия: 831 (100 из 103)
- 831-3102/037-000 831-3102/037-9037 831-3102/133-000 831-3103 831-3103/000-9037 831-3103/037-000 831-3103/037-9037 831-3103/133-000 831-3104 831-3104/000-9037 831-3104/037-000 831-3104/037-9037 831-3104/135-000 831-3105 831-3105/000-9035 831-3105/000-9037 831-3105/037-000 831-3105/037-9037 831-3105/1019-004 831-3105/1019-050 831-3105/135-000 831-3106 831-3106/000-9037 831-3106/037-000 831-3106/037-9037 831-3106/135-000 831-3107 831-3107/000-9037 831-3107/037-000 831-3107/037-9037 831-3107/136-000 831-3108 831-3108/000-9037 831-3108/037-000 831-3108/037-9037 831-3108/136-000 831-3109 831-3109/037-000 831-3109/136-000 831-3202 831-3202/000-9034 831-3202/007-000 831-3202/007-9034 831-3202/133-000 831-3203 831-3203/000-9034 831-3203/007-000 831-3203/007-9034 831-3203/133-000 831-3204 831-3204/000-9034 831-3204/007-000 831-3204/007-9034 831-3204/135-000 831-3205 831-3205/000-9032 831-3205/000-9034 831-3205/007-000 831-3205/007-9034 831-3205/1020-004 831-3205/1020-050 831-3205/135-000 831-3206 831-3206/000-9034 831-3206/007-000 831-3206/007-9034 831-3206/135-000 831-3207 831-3207/000-9034 831-3207/007-000 831-3207/007-9034 831-3207/136-000 831-3208 831-3208/000-9034 831-3208/007-000 831-3208/007-9034 831-3208/136-000 831-3209 831-3209/007-000 831-3209/136-000 831-3602 831-3603 831-3604 831-3605 831-3606 831-3607 831-3608 831-3609 831-3622 831-3623 831-3624 831-3625 831-3626 831-3627 831-3628 831-3629 831-500 831-503 831-505 831-506
8313205/1020050, 831 3205/1020 050
