Datasheet Wago 890-102 — Даташит
Серия890
Модель890-102
Разъем; с корпусом разгрузки натяжения; 2-пол.; Код. A
25 предложений от 12 поставщиков
Соединители, Mains connector ATT.LOV.SERIES_POWERCONNECTORS WINSTA MINI Socket, straight Total number of pins: 2 16A Black WAGO 1
208 ₽
325 ₽
Зенер
Россия и страны ТС
890-102
от 609 ₽
DIP8.RU
Россия и страны ТС
890-102
от 646 ₽
Wago 890-102 Wago 890-102
Actuation typeOperating tool Push-in
CodingA
Цветblack
Connectable sheathed cable diameter3.8 … 8.2 mm
Country of originDE
Degree of protectionIP20
Габариты: глубина61.6 mm / 2.425 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
Fire load0.14 MJ
GTIN4045454231729
Height13.2 mm / 0.52 inch
Locking leverнет
MarkingL N
Mismating protectionYes
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Number of Poles2
Potential markingL N
Product Group20 (WINSTA)
Rated current16 A
Rated voltage (III / 3)250 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Strain reliefStrain relief housing
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length32 мм
Total number of connection points2
Total number of potentials2
Вес5.614 г
Ширина15.6 mm / 0.614 inch
На английском языке: Datasheet Wago 890-102
