Datasheet Wago 890-105 — Даташит
Разъем; с корпусом разгрузки натяжения; 5-пол.; Код. A
![]() 13 предложений от 6 поставщиков Алюминиевые Электролитические Конденсаторы с Проволочными Выводами | |||
890-105 | от 1 105 ₽ | ||
890-105 Wago | от 1 149 ₽ | ||
8901-0.5 X 0.5-1000 3M | 2 459 ₽ | ||
8901-0.5"X 0.5"-1000 3M | 3 336 ₽ |
Actuation type | Operating tool Push-in |
Coding | A |
Цвет | black |
Connectable sheathed cable diameter | 6.5 … 10.5 mm |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 71.9 mm / 2.831 inch |
Fine-stranded conductor | 0.25 … 1.5 mm² / 22 … 16 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² / 22 … 20 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 0.75 mm² / 22 … 20 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 20 AWG |
Fire load | 0.29 MJ |
GTIN | 4045454232870 |
Height | 15.8 mm / 0.622 inch |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | N ⏚ 1 2 3 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Nominal cross section | 1.5 mm² |
Note (strip length) | see also packaging or instructions |
Number of Poles | 5 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | N ⏚ 1 2 3 |
Product Group | 20 (WINSTA) |
Rated current | 13 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Retention force of a plug-in connection | when locked: > 80N |
Solid conductor | 0.25 … 1.5 mm² / 22 … 16 AWG |
Solid conductor, push-in termination | 0.75 … 1.5 mm² / 20 … 16 AWG |
Strain relief | Strain relief housing |
Stranded conductor | 0.25 … 1 mm² / 22 … 18 AWG |
Strip length | 45 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of connection points | 5 |
Total number of potentials | 5 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 11.9 г |
Ширина | 26.7 mm / 1.051 inch |
Серия: 890 (100 из 384)
- 890-101 890-102 890-103 890-104 890-105 890-1102 890-1105 890-111 890-1112 890-1115 890-112 890-113 890-114 890-115 890-121 890-122 890-123 890-124 890-125 890-131 890-132 890-133 890-134 890-135 890-1601 890-1602 890-1603 890-1606 890-1615 890-1617 890-1620 890-1622 890-1631 890-1632 890-1633 890-1634 890-1636 890-1656 890-1661 890-1662 890-1663 890-1665 890-1672 890-1681 890-1682 890-1683 890-1684 890-1686 890-1701 890-1702 890-1703 890-1731 890-1732 890-1733 890-1734 890-1735 890-1736 890-1761 890-1762 890-1763 890-1781 890-1782 890-1783 890-1904 890-1907 890-202 890-202/342-000 890-203 890-204 890-205 890-2102 890-2105 890-2105/006-000 890-2112 890-2115 890-212 890-212/342-000 890-213 890-214 890-215 890-222 890-223 890-224 890-225 890-232 890-233 890-234 890-235 890-242 890-242/060-000 890-243 890-243/060-000 890-243/062-000 890-244 890-244/060-000 890-244/062-000 890-244/064-000 890-245 890-245/060-000 890-245/062-000
