Datasheet Wago 890-135 — Даташит
Серия890
Модель890-135
Штекер; с корпусом разгрузки натяжения; 5-пол.; Код. A
890-135, Штеккер С фиксирующей скобой 5-конт.
Оф. дистрибьютор
Wago 890-135 Wago 890-135
Actuation typeOperating tool Push-in
CodingA
Цветwhite
Connectable sheathed cable diameter6.5 … 10.5 mm
Country of originDE
Degree of protectionIP20
Габариты: глубина71.9 mm / 2.831 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
Fire load0.301 MJ
GTIN4045454233037
Height15.8 mm / 0.622 inch
Locking leverнет
MarkingN ⏚ 1 2 3
Mismating protectionYes
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Number of Poles5
Potential markingN ⏚ 1 2 3
Product Group20 (WINSTA)
Rated current13 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Strain reliefStrain relief housing
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length45 мм
Total number of connection points5
Total number of potentials5
Вес11.65 г
Ширина26.7 mm / 1.051 inch
На английском языке: Datasheet Wago 890-135
