Datasheet Wago 890-204 — Даташит
Серия890
Модель890-204
Разъем; 4-пол.; Код. A
19 предложений от 8 поставщиков
BOD8902-04 BAHCO Нейлоновый щуп 7X1000MM
Оптулс
1 206 ₽
Элитан
3 123 ₽
Wago 890-204
Actuation typeOperating tool Push-in
CodingA
Цветblack
Country of originPL
Degree of protectionIP20
Габариты: глубина34.1 mm / 1.343 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
Fire load0.095 MJ
GTIN4055143548557
Height11.7 mm / 0.461 inch
Locking leverнет
MarkingN ⏚ 2|L 1|L'
Mismating protectionYes
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Number of Poles4
Potential markingN ⏚ 2/L 1/L'
Product Group20 (WINSTA)
Rated current16 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points4
Total number of potentials4
Вес8.134 г
Ширина19.2 mm / 0.756 inch
На английском языке: Datasheet Wago 890-204
