Datasheet Wago 890-205 — Даташит
Серия890
Модель890-205
Разъем; 5-пол.; Код. A
10 предложений от 7 поставщиков
BOD8902-05 BAHCO Медный щуп 5X700MM
253 ₽
Элитан
1 003 ₽
8902-0.5 X 0.5-1000
3M
2 477 ₽
8902-0.5"X 0.5"-1000
3M
3 186 ₽
Wago 890-205
Actuation typeOperating tool Push-in
CodingA
Цветblack
Country of originPL
Degree of protectionIP20
Габариты: глубина34.1 mm / 1.343 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
Fire load0.112 MJ
GTIN4055143548571
Height11.7 mm / 0.461 inch
Locking leverнет
MarkingN ⏚ 1 2 3
Mismating protectionYes
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Number of Poles5
Potential markingN ⏚ 1 2 3
Product Group20 (WINSTA)
Rated current13 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points5
Total number of potentials5
Вес6.07 г
Ширина23.6 mm / 0.929 inch
На английском языке: Datasheet Wago 890-205
