Datasheet Wago 890-225 — Даташит
Разъем; 5-пол.; Код. A
SOCKET 5-POLE, WHITE | |||
| 890-225 Wago | по запросу | ||
| Actuation type | Operating tool Push-in |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Coding | A |
| Цвет | white |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper or copper alloy, surface-treated |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Degree of protection | IP20 |
| Габариты: глубина | 34.1 mm / 1.343 inch |
| Fine-stranded conductor | 0.25 … 1.5 mm² / 22 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² / 22 … 20 AWG |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 0.75 mm² / 22 … 20 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 20 AWG |
| Fire load | 0.112 MJ |
| GTIN | 4045454233204 |
| Height | 11.7 mm / 0.461 inch |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ 1 2 3 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Nominal cross section | 1.5 mm² |
| Note (strip length) | see also packaging or instructions |
| Number of Poles | 5 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | N ⏚ 1 2 3 |
| Product Group | 20 (WINSTA) |
| Rated current | 13 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Solid conductor | 0.25 … 1.5 mm² / 22 … 16 AWG |
| Solid conductor, push-in termination | 0.75 … 1.5 mm² / 20 … 16 AWG |
| Stranded conductor | 0.25 … 1 mm² / 22 … 18 AWG |
| Strip length | 9 mm / 0.35 Inch |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total number of connection points | 5 |
| Total number of potentials | 5 |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 6.025 г |
| Ширина | 23.6 mm / 0.929 inch |
Серия: 890 (100 из 384)
- 890-1632 890-1633 890-1634 890-1636 890-1656 890-1661 890-1662 890-1663 890-1665 890-1672 890-1681 890-1682 890-1683 890-1684 890-1686 890-1701 890-1702 890-1703 890-1731 890-1732 890-1733 890-1734 890-1735 890-1736 890-1761 890-1762 890-1763 890-1781 890-1782 890-1783 890-1904 890-1907 890-202 890-202/342-000 890-203 890-204 890-205 890-2102 890-2105 890-2105/006-000 890-2112 890-2115 890-212 890-212/342-000 890-213 890-214 890-215 890-222 890-223 890-224 890-225 890-232 890-233 890-234 890-235 890-242 890-242/060-000 890-243 890-243/060-000 890-243/062-000 890-244 890-244/060-000 890-244/062-000 890-244/064-000 890-245 890-245/060-000 890-245/062-000 890-252 890-252/060-000 890-253 890-253/060-000 890-253/062-000 890-254 890-254/060-000 890-254/062-000 890-254/064-000 890-255 890-255/060-000 890-255/062-000 890-262 890-263 890-263/071-000 890-263/073-000 890-264 890-264/071-000 890-264/072-000 890-264/073-000 890-265 890-265/073-000 890-272 890-273 890-273/071-000 890-273/073-000 890-274 890-274/071-000 890-274/072-000 890-274/073-000 890-275 890-275/073-000 890-282
