Datasheet Wago 890-232 — Даташит
Серия890
Модель890-232
Штекер; 2-пол.; Код. A
16 предложений от 5 поставщиков
PLUG 2-POLE, WHITE
Зенер
Россия и страны ТС
890-232
от 308 ₽
890-232
от 402 ₽
Элитан
441 ₽
Wago 890-232
Actuation typeOperating tool Push-in
CodingA
Цветwhite
Country of originPL
Degree of protectionIP20
Габариты: глубина34.1 mm / 1.343 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
Fire load0.056 MJ
GTIN4055143548496
Height11.7 mm / 0.461 inch
Locking leverнет
MarkingL N
Mismating protectionYes
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Number of Poles2
Potential markingL N
Product Group20 (WINSTA)
Rated current16 A
Rated voltage (III / 3)250 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points2
Total number of potentials2
Вес2.51 г
Ширина10.4 mm / 0.409 inch
На английском языке: Datasheet Wago 890-232
