Datasheet Wago 890-243/060-000 — Даташит
Серия890
Модель890-243/060-000
Разъем; 3-пол.; Код. B
Actuation typeOperating tool Push-in
CodingB
Цветgray
Country of originPL
Degree of protectionIP20
Габариты: глубина34.1 mm / 1.343 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
Fire load0.07 MJ
GTIN4055143499880
Height11.7 mm / 0.461 inch
Locking leverнет
MarkingL ⏚ N
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Note on rated current13 A for 3-pole load
Number of Poles3
Potential markingL ⏚ N
Product Group20 (WINSTA)
Rated current16 A
Rated voltage (III / 3)250 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points3
Total number of potentials3
Вес3.5 г
Ширина15 mm / 0.591 inch
890243/060000, 890 243/060 000
На английском языке: Datasheet Wago 890-243/060-000
