Datasheet Wago 890-252/060-000 — Даташит
Серия890
Модель890-252/060-000
Штекер; 2-пол.; Код. B
Actuation typeOperating tool Push-in
CodingB
Цветgray
Country of originPL
Degree of protectionIP20
Габариты: глубина34.1 mm / 1.343 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
GTIN4055143499644
Height11.7 mm / 0.461 inch
Locking leverнет
MarkingL N
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Number of Poles2
Potential markingL N
Rated current16 A
Rated voltage (III / 3)250 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points2
Total number of potentials2
Вес2.46 г
Ширина10.4 mm / 0.409 inch
890252/060000, 890 252/060 000
На английском языке: Datasheet Wago 890-252/060-000
