Datasheet Wago 890-254/062-000 — Даташит
Серия890
Модель890-254/062-000
Штекер; 4-пол.; Код. B
14 предложений от 3 поставщиков
PLUG, 4-POLE, GRAY
Зенер
Россия и страны ТС
890-254
от 588 ₽
890-254
от 768 ₽
Actuation typeOperating tool Push-in
CodingB
Цветgray
Country of originPL
Degree of protectionIP20
Габариты: глубина34.1 mm / 1.343 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
GTIN4055143523578
Height11.7 mm / 0.461 inch
Locking leverнет
Marking3 PE 2 1
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Note on rated current13 A for 3-pole load10 A for 4-pole load
Number of Poles4
Potential marking3 PE 2 1
Rated current16 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points4
Total number of potentials4
Вес4.527 г
Ширина19.2 mm / 0.756 inch
890254/062000, 890 254/062 000
На английском языке: Datasheet Wago 890-254/062-000
