Datasheet Wago 890-264/071-000 — Даташит
Серия890
Модель890-264/071-000
Разъем; 4-пол.; Код. B
16 предложений от 5 поставщиков
SOCKET 4-POLE, LIGHT GREEN
890-264
от 916 ₽
Элитан
1 267 ₽
Actuation typeOperating tool Push-in
CodingB
Цветlight green
Country of originPL
Degree of protectionIP20
Габариты: глубина34.1 mm / 1.343 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
GTIN4055143523547
Height11.7 mm / 0.461 inch
Locking leverнет
MarkingU- S U+ X/Y
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Note on rated current13 A for 3-pole load10 A for 4-pole load
Number of Poles4
Potential markingU- S U+ X/Y
Rated current16 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points4
Total number of potentials4
Вес4.862 г
Ширина19.2 mm / 0.756 inch
890264/071000, 890 264/071 000
На английском языке: Datasheet Wago 890-264/071-000
