Datasheet Wago 890-723 — Даташит
Серия890
Модель890-723
Защелкивающаяся розетка; 3-пол.; Код. A
Wago 890-723
Actuation typeOperating tool Push-in
CodingA
Цветwhite
Country of originPL
Degree of protectionIP20
Габариты: глубина39.85 mm / 1.569 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
Fire load0.138 MJ
GTIN4045454233501
Gehäuseblechstärke0.5 … 2 mm / 0.02 … 0.079 inch
Height16 mm / 0.63 inch
Locking leverда
MarkingL ⏚ N
Mismating protectionYes
Mounting typeSnap-in
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Number of Poles3
Potential markingL ⏚ N
Product Group20 (WINSTA)
Rated current16 A
Rated voltage (III / 3)250 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points3
Total number of potentials3
Вес6.1 г
Ширина24.2 mm / 0.953 inch
На английском языке: Datasheet Wago 890-723
