Datasheet Wago 890-725 — Даташит
Серия890
Модель890-725
Защелкивающаяся розетка; 5-пол.; Код. A
6 предложений от 3 поставщиков
SNAP-IN SOCKET WITHOUT LOCKING L
890-725
от 993 ₽
Элитан
2 301 ₽
Wago 890-725
Actuation typeOperating tool Push-in
CodingA
Цветwhite
Country of originPL
Degree of protectionIP20
Габариты: глубина39.85 mm / 1.569 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
Fire load0.202 MJ
GTIN4045454233525
Gehäuseblechstärke0.5 … 2 mm / 0.02 … 0.079 inch
Height17.5 mm / 0.689 inch
Locking leverда
MarkingN ⏚ 1 2 3
Mismating protectionYes
Mounting typeSnap-in
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Number of Poles5
Potential markingN ⏚ 1 2 3
Product Group20 (WINSTA)
Rated current13 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points5
Total number of potentials5
Вес9.015 г
Ширина35.5 mm / 1.398 inch
На английском языке: Datasheet Wago 890-725
