Datasheet Wago 890-754/060-000 — Даташит
Серия890
Модель890-754/060-000
Защелкивающийся штекер; 4-пол.; Код. B
15 предложений от 4 поставщиков
SNAP-IN PLUG GRAY
Зенер
Россия и страны ТС
890-754
от 576 ₽
Элитан
726 ₽
890-754
от 751 ₽
Actuation typeOperating tool Push-in
CodingB
Цветgray
Country of originPL
Degree of protectionIP20
Габариты: глубина39.8 mm / 1.567 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
Fire load0.167 MJ
GTIN4055143427685
Gehäuseblechstärke0.5 … 2 mm / 0.02 … 0.079 inch
Height16 mm / 0.63 inch
Locking leverда
MarkingN ⏚ 2|L 1|L'
Mounting typeSnap-in
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Note on rated current13 A for 3-pole load10 A for 4-pole load
Number of Poles4
Potential markingN ⏚ 2/L 1/L'
Rated current16 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points4
Total number of potentials4
Вес6.895 г
Ширина28.6 mm / 1.126 inch
890754/060000, 890 754/060 000
На английском языке: Datasheet Wago 890-754/060-000
