Datasheet Wago 890-755 — Даташит
Серия890
Модель890-755
Защелкивающийся штекер; 5-пол.; Код. B
Элитан
873 ₽
Wago 890-755
Actuation typeOperating tool Push-in
CodingB
Цветgray
Country of originPL
Degree of protectionIP20
Габариты: глубина39.85 mm / 1.569 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
GTIN4055143235969
Gehäuseblechstärke0.5 … 2 mm / 0.02 … 0.079 inch
Height17.5 mm / 0.689 inch
Locking leverда
Marking1 2 3 4 5
Mounting typeSnap-in
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Note on rated current13 A for 3-pole load10 A for 4- and 5-pole load
Number of Poles5
Packaging typeBOX
Potential marking1 2 3 4 5
Rated current16 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points5
Total number of potentials5
Вес8.031 г
Ширина35.5 mm / 1.398 inch
На английском языке: Datasheet Wago 890-755
