Datasheet Wago 890-792/082-000 — Даташит
Защелкивающийся штекер; 2-пол.; Код. B
| 890-792/082-000 Wago | по запросу | ||
| Actuation type | Operating tool Push-in |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Coding | B |
| Цвет | pink |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper or copper alloy, surface-treated |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | PL |
| Degree of protection | IP20 |
| Габариты: глубина | 39.85 mm / 1.569 inch |
| Fine-stranded conductor | 0.25 … 1.5 mm² / 22 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² / 22 … 20 AWG |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 0.75 mm² / 22 … 20 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 20 AWG |
| GTIN | 4055143428224 |
| Gehäuseblechstärke | 0.5 … 2 mm / 0.02 … 0.079 inch |
| Height | 16 mm / 0.63 inch |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Marking | + - |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mounting type | Snap-in |
| Nominal cross section | 1.5 mm² |
| Note (strip length) | see also packaging or instructions |
| Number of Poles | 2 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | + - |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Solid conductor | 0.25 … 1.5 mm² / 22 … 16 AWG |
| Solid conductor, push-in termination | 0.75 … 1.5 mm² / 20 … 16 AWG |
| Stranded conductor | 0.25 … 1 mm² / 22 … 18 AWG |
| Strip length | 9 mm / 0.35 Inch |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total number of connection points | 2 |
| Total number of potentials | 2 |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 4.26 г |
| Ширина | 19.8 mm / 0.78 inch |
Серия: 890 (100 из 384)
- 890-743/062-000 890-744 890-744/060-000 890-744/062-000 890-744/064-000 890-745/060-000 890-745/062-000 890-752 890-752/060-000 890-753 890-753/060-000 890-753/062-000 890-754 890-754/060-000 890-754/062-000 890-754/064-000 890-755 890-755/060-000 890-755/062-000 890-762 890-763 890-763/071-000 890-763/073-000 890-764 890-764/071-000 890-764/072-000 890-764/073-000 890-765 890-765/073-000 890-772 890-773 890-773/071-000 890-773/073-000 890-774 890-774/071-000 890-774/072-000 890-774/073-000 890-775/073-000 890-782 890-782/080-000 890-782/082-000 890-783 890-783/081-000 890-783/082-000 890-784 890-784/081-000 890-785/080-000 890-785/082-000 890-792 890-792/080-000 890-792/082-000 890-793 890-793/081-000 890-793/082-000 890-794 890-794/081-000 890-795/080-000 890-795/082-000 890-802 890-802/011-000 890-812 890-813/011-000 890-814 890-814/011-000 890-815 890-815/011-000 890-822 890-822/011-000 890-823 890-823/011-000 890-824 890-824/011-000 890-825 890-825/011-000 890-832 890-832/011-000 890-833 890-833/011-000 890-834 890-834/011-000 890-835 890-835/011-000 890-842 890-842/011-000 890-843 890-843/011-000 890-844 890-844/011-000 890-845 890-845/011-000 890-852 890-852/011-000 890-853 890-853/011-000 890-854 890-854/011-000 890-855 890-855/011-000 890-862 890-862/011-000
890792/082000, 890 792/082 000
