Datasheet Wago 890-1112 — Даташит
Серия890
Модель890-1112
Штекер; 2-пол.; Код. I
13 предложений от 5 поставщиков
Прямоугольные Разъемы Питания
197 ₽
890-1112
от 341 ₽
Элитан
441 ₽
Wago 890-1112
Actuation typeOperating tool Push-in
CodingI
Цветblue
Country of originPL
Degree of protectionIP20
Габариты: глубина34.1 mm / 1.343 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
Fire load0.056 MJ
GTIN4055143548502
Height11.7 mm / 0.461 inch
Locking leverнет
Marking+ -
Mismating protectionYes
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Number of Poles2
Potential marking+ -
Product Group20 (WINSTA)
Rated current16 A
Rated voltage (III / 3)250 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points2
Total number of potentials2
Вес2.53 г
Ширина10.4 mm / 0.409 inch
8901112, 890 1112
На английском языке: Datasheet Wago 890-1112
