Datasheet Wago 890-1115 — Даташит
Серия890
Модель890-1115
Штекер; 5-пол.; Код. I
, TAPE SPLIC 11 1/2"X 11 1/2" 25RL
Элитан
1 169 ₽
8901-11.5 X 11.5-25
3M
8 403 ₽
8901-11.5"X 11.5"-25
3M
11 468 ₽
Wago 890-1115
Actuation typeOperating tool Push-in
CodingI
Цветblue
Country of originPL
Degree of protectionIP20
Габариты: глубина34.1 mm / 1.343 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
Fire load0.12 MJ
GTIN4055143548601
Height11.7 mm / 0.461 inch
Locking leverнет
MarkingN ⏚ L - +
Mismating protectionYes
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Number of Poles5
Potential markingN ⏚ L - +
Product Group20 (WINSTA)
Rated current16 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points5
Total number of potentials5
Вес5.7 г
Ширина23.6 mm / 0.929 inch
8901115, 890 1115
На английском языке: Datasheet Wago 890-1115
