Datasheet Wago 890-1686 — Даташит
Ч-образный распределительный соединитель; однонаправленные; 1 штекер / 2 розетки; 2-пол.; для тонких проволочных выводов; с третьим фиксирующим рычагом
| H-DISTRIBUTION CONNECTOR 2-POLE | |||
| 890-1686 Wago | по запросу | ||
| Coding | A |
| Цвет | white |
| Contact material | Copper or copper alloy, surface-treated |
| Contact type (pluggable connector) | Socket/plug |
| Country of origin | DE |
| Degree of protection | IP20 |
| Габариты: глубина | 57.85 mm / 2.278 inch |
| Fire load | 0.185 MJ |
| GTIN | 4045454404437 |
| Height | 29 mm / 1.142 inch |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Marking | L N |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 2 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | L N |
| Product Group | 20 (WINSTA) |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total number of potentials | 2 |
| Type of distribution connector | h-distribution connector, unidirectional |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 9.808 г |
| Ширина | 12 mm / 0.472 inch |
Серия: 890 (100 из 384)
- 890-101 890-102 890-103 890-104 890-105 890-1102 890-1105 890-111 890-1112 890-1115 890-112 890-113 890-114 890-115 890-121 890-122 890-123 890-124 890-125 890-131 890-132 890-133 890-134 890-135 890-1601 890-1602 890-1603 890-1606 890-1615 890-1617 890-1620 890-1622 890-1631 890-1632 890-1633 890-1634 890-1636 890-1656 890-1661 890-1662 890-1663 890-1665 890-1672 890-1681 890-1682 890-1683 890-1684 890-1686 890-1701 890-1702 890-1703 890-1731 890-1732 890-1733 890-1734 890-1735 890-1736 890-1761 890-1762 890-1763 890-1781 890-1782 890-1783 890-1904 890-1907 890-202 890-202/342-000 890-203 890-204 890-205 890-2102 890-2105 890-2105/006-000 890-2112 890-2115 890-212 890-212/342-000 890-213 890-214 890-215 890-222 890-223 890-224 890-225 890-232 890-233 890-234 890-235 890-242 890-242/060-000 890-243 890-243/060-000 890-243/062-000 890-244 890-244/060-000 890-244/062-000 890-244/064-000 890-245 890-245/060-000 890-245/062-000
8901686, 890 1686
