Datasheet Wago 891-8985/006-202 — Даташит
Соединительный кабель; Розетка - штекер; 5-пол.; длиной 2 м; Кодирование I; напр., функция диммирования (DALI); с изоляцией из ПВХ
| 891-8985/006-602 Wago | по запросу | ||
| Coding | I |
| Цвет | blue |
| Color of sheathed cable | white |
| Connection type | Socket - Plug |
| Connector color | blue |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | PL |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 9.3 … 11.6 mm |
| Fire load | 6.067 MJ |
| GTIN | 4055143398435 |
| Ground function | with preceding GND contact |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ L - + |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | N ⏚ L - + |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | black |
| Rated current | 16 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | white |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 2 m |
| Total number of potentials | 5 |
| Type of cable | H05VV-F 5G1.5 |
| Type of cable assembly | Interconnecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 354.484 г |
Серия: 891 (100 из 1377)
- 891-8982/116-102 891-8982/116-201 891-8982/116-202 891-8982/116-301 891-8982/116-302 891-8982/116-401 891-8982/116-402 891-8982/116-501 891-8982/116-502 891-8982/116-601 891-8982/116-602 891-8982/116-701 891-8982/116-702 891-8982/116-801 891-8982/116-802 891-8982/206-101 891-8982/206-102 891-8982/206-201 891-8982/206-202 891-8982/206-301 891-8982/206-302 891-8982/206-401 891-8982/206-402 891-8982/206-501 891-8982/206-502 891-8982/206-601 891-8982/206-602 891-8982/206-701 891-8982/206-702 891-8982/206-801 891-8982/206-802 891-8982/216-101 891-8982/216-102 891-8982/216-201 891-8982/216-202 891-8982/216-301 891-8982/216-302 891-8982/216-401 891-8982/216-402 891-8982/216-501 891-8982/216-502 891-8982/216-601 891-8982/216-602 891-8982/216-701 891-8982/216-702 891-8982/216-801 891-8982/216-802 891-8985/006-101 891-8985/006-102 891-8985/006-201 891-8985/006-202 891-8985/006-301 891-8985/006-302 891-8985/006-401 891-8985/006-402 891-8985/006-501 891-8985/006-502 891-8985/006-601 891-8985/006-602 891-8985/006-701 891-8985/006-702 891-8985/006-801 891-8985/006-802 891-8985/016-101 891-8985/016-102 891-8985/016-201 891-8985/016-202 891-8985/016-301 891-8985/016-302 891-8985/016-401 891-8985/016-402 891-8985/016-501 891-8985/016-502 891-8985/016-601 891-8985/016-602 891-8985/016-701 891-8985/016-702 891-8985/016-801 891-8985/016-802 891-8985/106-101 891-8985/106-102 891-8985/106-201 891-8985/106-202 891-8985/106-301 891-8985/106-302 891-8985/106-401 891-8985/106-402 891-8985/106-501 891-8985/106-502 891-8985/106-601 891-8985/106-602 891-8985/106-701 891-8985/106-702 891-8985/106-801 891-8985/106-802 891-8985/116-101 891-8985/116-102 891-8985/116-201 891-8985/116-202 891-8985/116-301
8918985/006202, 891 8985/006 202
