Datasheet Wago 891-8985/206-202 — Даташит
Соединительный кабель; Штекер - свободный конец; 5-пол.; длиной 2 м; Кодирование I; напр., функция диммирования (DALI); с изоляцией из ПВХ; Концы проводников, припаянные: 9 мм
| 891-8985/206-802 Wago | по запросу | ||
| Coding | I |
| Цвет | blue |
| Color of sheathed cable | white |
| Conductor preparation | tip-bonded |
| Connection type | Plug - free end |
| Connector color | blue |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 9.3 … 11.6 mm |
| Fire load | 5.811 MJ |
| GTIN | 4050821018346 |
| Ground function | with preceding GND contact |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ L - + |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Packaging type | not packed |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | N ⏚ L - + |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | black |
| Rated current | 16 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | white |
| Strip length | 45 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 2 m |
| Total number of potentials | 5 |
| Type of cable | H05VV-F 5G1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 338.17 г |
Серия: 891 (100 из 1377)
- 891-8985/016-102 891-8985/016-201 891-8985/016-202 891-8985/016-301 891-8985/016-302 891-8985/016-401 891-8985/016-402 891-8985/016-501 891-8985/016-502 891-8985/016-601 891-8985/016-602 891-8985/016-701 891-8985/016-702 891-8985/016-801 891-8985/016-802 891-8985/106-101 891-8985/106-102 891-8985/106-201 891-8985/106-202 891-8985/106-301 891-8985/106-302 891-8985/106-401 891-8985/106-402 891-8985/106-501 891-8985/106-502 891-8985/106-601 891-8985/106-602 891-8985/106-701 891-8985/106-702 891-8985/106-801 891-8985/106-802 891-8985/116-101 891-8985/116-102 891-8985/116-201 891-8985/116-202 891-8985/116-301 891-8985/116-302 891-8985/116-401 891-8985/116-402 891-8985/116-501 891-8985/116-502 891-8985/116-601 891-8985/116-602 891-8985/116-701 891-8985/116-702 891-8985/116-801 891-8985/116-802 891-8985/206-101 891-8985/206-102 891-8985/206-201 891-8985/206-202 891-8985/206-301 891-8985/206-302 891-8985/206-401 891-8985/206-402 891-8985/206-501 891-8985/206-502 891-8985/206-601 891-8985/206-602 891-8985/206-701 891-8985/206-702 891-8985/206-801 891-8985/206-802 891-8985/215-701 891-8985/216-101 891-8985/216-102 891-8985/216-201 891-8985/216-202 891-8985/216-301 891-8985/216-302 891-8985/216-401 891-8985/216-402 891-8985/216-501 891-8985/216-502 891-8985/216-601 891-8985/216-602 891-8985/216-701 891-8985/216-702 891-8985/216-801 891-8985/216-802 891-8992/005-101 891-8992/005-102 891-8992/005-103 891-8992/005-105 891-8992/005-107 891-8992/005-201 891-8992/005-202 891-8992/005-203 891-8992/005-205 891-8992/005-207 891-8992/005-301 891-8992/005-302 891-8992/005-303 891-8992/005-305 891-8992/005-307 891-8992/005-401 891-8992/005-402 891-8992/005-403 891-8992/005-405 891-8992/005-407
8918985/206202, 891 8985/206 202
