Datasheet Wago 891-8992/005-505 — Даташит
Соединительный кабель; Розетка - штекер; 2-пол.; Кодирование B; длиной 5 м; с изоляцией из ПВХ
| 891-8992/106-801 Wago | по запросу | ||
| Coding | B |
| Цвет | light green |
| Color of sheathed cable | gray |
| Connection type | Socket - Plug |
| Connector color | light green |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 5.9 … 7.5 mm |
| Fire load | 5.941 MJ |
| GTIN | 4050821654865 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | 1 2 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Number of Poles | 2 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | 1 2 |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | white |
| Rated current | 10 A |
| Rated voltage (III / 3) | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 5 m |
| Total number of potentials | 2 |
| Type of cable | Control line 2 x 1 |
| Type of cable assembly | Interconnecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 245 г |
Серия: 891 (100 из 1377)
- 891-8985/206-401 891-8985/206-402 891-8985/206-501 891-8985/206-502 891-8985/206-601 891-8985/206-602 891-8985/206-701 891-8985/206-702 891-8985/206-801 891-8985/206-802 891-8985/215-701 891-8985/216-101 891-8985/216-102 891-8985/216-201 891-8985/216-202 891-8985/216-301 891-8985/216-302 891-8985/216-401 891-8985/216-402 891-8985/216-501 891-8985/216-502 891-8985/216-601 891-8985/216-602 891-8985/216-701 891-8985/216-702 891-8985/216-801 891-8985/216-802 891-8992/005-101 891-8992/005-102 891-8992/005-103 891-8992/005-105 891-8992/005-107 891-8992/005-201 891-8992/005-202 891-8992/005-203 891-8992/005-205 891-8992/005-207 891-8992/005-301 891-8992/005-302 891-8992/005-303 891-8992/005-305 891-8992/005-307 891-8992/005-401 891-8992/005-402 891-8992/005-403 891-8992/005-405 891-8992/005-407 891-8992/005-501 891-8992/005-502 891-8992/005-503 891-8992/005-505 891-8992/005-507 891-8992/005-601 891-8992/005-602 891-8992/005-603 891-8992/005-605 891-8992/005-607 891-8992/005-701 891-8992/005-702 891-8992/005-703 891-8992/005-705 891-8992/005-707 891-8992/005-801 891-8992/005-802 891-8992/005-803 891-8992/005-805 891-8992/005-807 891-8992/006-101 891-8992/006-102 891-8992/006-103 891-8992/006-105 891-8992/006-107 891-8992/006-201 891-8992/006-202 891-8992/006-203 891-8992/006-205 891-8992/006-207 891-8992/006-301 891-8992/006-302 891-8992/006-303 891-8992/006-305 891-8992/006-307 891-8992/006-401 891-8992/006-402 891-8992/006-403 891-8992/006-405 891-8992/006-407 891-8992/006-501 891-8992/006-502 891-8992/006-503 891-8992/006-505 891-8992/006-507 891-8992/006-601 891-8992/006-602 891-8992/006-603 891-8992/006-605 891-8992/006-607 891-8992/006-701 891-8992/006-702 891-8992/006-703
8918992/005505, 891 8992/005 505
