Datasheet Wago 891-8992/006-407 — Даташит
Соединительный кабель; Розетка - штекер; 2-пол.; Кодирование B; длиной 4 м; с изоляцией из ПВХ
| 891-8992/106-801 Wago | по запросу | ||
| Coding | B |
| Цвет | pink |
| Color of sheathed cable | gray |
| Connection type | Socket - Plug |
| Connector color | pink |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 6.8 … 8.6 mm |
| GTIN | 4055143511100 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | 1 2 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Number of Poles | 2 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | 1 2 |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | white |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 4 m |
| Total number of potentials | 2 |
| Type of cable | Control line 2 x 1.5 |
| Type of cable assembly | Interconnecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 268.846 г |
Серия: 891 (100 из 1377)
- 891-8992/005-207 891-8992/005-301 891-8992/005-302 891-8992/005-303 891-8992/005-305 891-8992/005-307 891-8992/005-401 891-8992/005-402 891-8992/005-403 891-8992/005-405 891-8992/005-407 891-8992/005-501 891-8992/005-502 891-8992/005-503 891-8992/005-505 891-8992/005-507 891-8992/005-601 891-8992/005-602 891-8992/005-603 891-8992/005-605 891-8992/005-607 891-8992/005-701 891-8992/005-702 891-8992/005-703 891-8992/005-705 891-8992/005-707 891-8992/005-801 891-8992/005-802 891-8992/005-803 891-8992/005-805 891-8992/005-807 891-8992/006-101 891-8992/006-102 891-8992/006-103 891-8992/006-105 891-8992/006-107 891-8992/006-201 891-8992/006-202 891-8992/006-203 891-8992/006-205 891-8992/006-207 891-8992/006-301 891-8992/006-302 891-8992/006-303 891-8992/006-305 891-8992/006-307 891-8992/006-401 891-8992/006-402 891-8992/006-403 891-8992/006-405 891-8992/006-407 891-8992/006-501 891-8992/006-502 891-8992/006-503 891-8992/006-505 891-8992/006-507 891-8992/006-601 891-8992/006-602 891-8992/006-603 891-8992/006-605 891-8992/006-607 891-8992/006-701 891-8992/006-702 891-8992/006-703 891-8992/006-705 891-8992/006-707 891-8992/006-801 891-8992/006-802 891-8992/006-803 891-8992/006-805 891-8992/006-807 891-8992/015-101 891-8992/015-102 891-8992/015-201 891-8992/015-202 891-8992/015-301 891-8992/015-302 891-8992/015-401 891-8992/015-402 891-8992/015-501 891-8992/015-502 891-8992/015-601 891-8992/015-602 891-8992/015-701 891-8992/015-702 891-8992/015-801 891-8992/015-802 891-8992/016-101 891-8992/016-102 891-8992/016-201 891-8992/016-202 891-8992/016-301 891-8992/016-302 891-8992/016-401 891-8992/016-402 891-8992/016-501 891-8992/016-502 891-8992/016-601 891-8992/016-602 891-8992/016-701
8918992/006407, 891 8992/006 407
