Datasheet Wago 891-8992/106-307 — Даташит
Соединительный кабель; Розетка - свободный конец; 2-пол.; Кодирование B; длиной 3 м; с изоляцией из ПВХ
| 891-8992/106-705 Wago | по запросу | ||
| Coding | B |
| Цвет | pink |
| Color of sheathed cable | gray |
| Conductor preparation | tip-bonded |
| Connection type | Socket - free end |
| Connector color | pink |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 6.8 … 8.6 mm |
| Fire load | 4.88 MJ |
| GTIN | 4050821675488 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | 1 2 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Number of Poles | 2 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | 1 2 |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | white |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 32 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 3 m |
| Total number of potentials | 2 |
| Type of cable | Control line 2 x 1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 199.282 г |
Серия: 891 (100 из 1377)
- 891-8992/105-107 891-8992/105-201 891-8992/105-202 891-8992/105-203 891-8992/105-205 891-8992/105-207 891-8992/105-301 891-8992/105-302 891-8992/105-303 891-8992/105-305 891-8992/105-307 891-8992/105-401 891-8992/105-402 891-8992/105-403 891-8992/105-405 891-8992/105-407 891-8992/105-501 891-8992/105-502 891-8992/105-503 891-8992/105-505 891-8992/105-507 891-8992/105-601 891-8992/105-602 891-8992/105-603 891-8992/105-605 891-8992/105-607 891-8992/105-701 891-8992/105-702 891-8992/105-703 891-8992/105-705 891-8992/105-707 891-8992/105-801 891-8992/105-802 891-8992/105-803 891-8992/105-805 891-8992/105-807 891-8992/106-101 891-8992/106-102 891-8992/106-103 891-8992/106-105 891-8992/106-107 891-8992/106-201 891-8992/106-202 891-8992/106-203 891-8992/106-205 891-8992/106-207 891-8992/106-301 891-8992/106-302 891-8992/106-303 891-8992/106-305 891-8992/106-307 891-8992/106-401 891-8992/106-402 891-8992/106-403 891-8992/106-405 891-8992/106-407 891-8992/106-501 891-8992/106-502 891-8992/106-503 891-8992/106-505 891-8992/106-507 891-8992/106-601 891-8992/106-602 891-8992/106-603 891-8992/106-605 891-8992/106-607 891-8992/106-701 891-8992/106-702 891-8992/106-703 891-8992/106-705 891-8992/106-707 891-8992/106-801 891-8992/106-802 891-8992/106-803 891-8992/106-805 891-8992/106-807 891-8992/115-101 891-8992/115-102 891-8992/115-201 891-8992/115-202 891-8992/115-301 891-8992/115-302 891-8992/115-401 891-8992/115-402 891-8992/115-501 891-8992/115-502 891-8992/115-601 891-8992/115-602 891-8992/115-701 891-8992/115-702 891-8992/115-801 891-8992/115-802 891-8992/116-101 891-8992/116-102 891-8992/116-201 891-8992/116-202 891-8992/116-301 891-8992/116-302 891-8992/116-401 891-8992/116-402
8918992/106307, 891 8992/106 307
