Datasheet Wago 891-8992/205-403 — Даташит
Соединительный кабель; Штекер - свободный конец; 2-пол.; Кодирование B; длиной 4 м; с изоляцией из ПВХ
| 891-8992/106-801 Wago | по запросу | ||
| Coding | B |
| Цвет | gray |
| Color of sheathed cable | gray |
| Conductor preparation | tip-bonded |
| Connection type | Plug - free end |
| Connector color | gray |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 5.9 … 7.5 mm |
| Fire load | 4.682 MJ |
| GTIN | 4050821483748 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | 1 2 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Number of Poles | 2 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | 1 2 |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | white |
| Rated current | 10 A |
| Rated voltage (III / 3) | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 32 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 4 m |
| Total number of potentials | 2 |
| Type of cable | Control line 2 x 1 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 195 г |
Серия: 891 (100 из 1377)
- 891-8992/106-807 891-8992/115-101 891-8992/115-102 891-8992/115-201 891-8992/115-202 891-8992/115-301 891-8992/115-302 891-8992/115-401 891-8992/115-402 891-8992/115-501 891-8992/115-502 891-8992/115-601 891-8992/115-602 891-8992/115-701 891-8992/115-702 891-8992/115-801 891-8992/115-802 891-8992/116-101 891-8992/116-102 891-8992/116-201 891-8992/116-202 891-8992/116-301 891-8992/116-302 891-8992/116-401 891-8992/116-402 891-8992/116-501 891-8992/116-502 891-8992/116-601 891-8992/116-602 891-8992/116-701 891-8992/116-702 891-8992/116-801 891-8992/116-802 891-8992/205-101 891-8992/205-102 891-8992/205-103 891-8992/205-105 891-8992/205-107 891-8992/205-201 891-8992/205-202 891-8992/205-203 891-8992/205-205 891-8992/205-207 891-8992/205-301 891-8992/205-302 891-8992/205-303 891-8992/205-305 891-8992/205-307 891-8992/205-401 891-8992/205-402 891-8992/205-403 891-8992/205-405 891-8992/205-407 891-8992/205-501 891-8992/205-502 891-8992/205-503 891-8992/205-505 891-8992/205-507 891-8992/205-601 891-8992/205-602 891-8992/205-603 891-8992/205-605 891-8992/205-607 891-8992/205-701 891-8992/205-702 891-8992/205-703 891-8992/205-705 891-8992/205-707 891-8992/205-801 891-8992/205-802 891-8992/205-803 891-8992/205-805 891-8992/205-807 891-8992/206-101 891-8992/206-102 891-8992/206-103 891-8992/206-105 891-8992/206-107 891-8992/206-201 891-8992/206-202 891-8992/206-203 891-8992/206-205 891-8992/206-207 891-8992/206-301 891-8992/206-302 891-8992/206-303 891-8992/206-305 891-8992/206-307 891-8992/206-401 891-8992/206-402 891-8992/206-403 891-8992/206-405 891-8992/206-407 891-8992/206-501 891-8992/206-502 891-8992/206-503 891-8992/206-505 891-8992/206-507 891-8992/206-601 891-8992/206-602
8918992/205403, 891 8992/205 403
