Datasheet Wago 891-8992/205-505 — Даташит
Соединительный кабель; Штекер - свободный конец; 2-пол.; Кодирование B; длиной 5 м; с изоляцией из ПВХ
891-8992/106-801 Wago | по запросу |
Coding | B |
Цвет | light green |
Color of sheathed cable | gray |
Conductor preparation | tip-bonded |
Connection type | Plug - free end |
Connector color | light green |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Cross section of single conductor | 1 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 5.9 … 7.5 mm |
Fire load | 5.822 MJ |
GTIN | 4050821483670 |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | 1 2 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Number of Poles | 2 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | 1 2 |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | white |
Rated current | 10 A |
Rated voltage (III / 3) | 250 В |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | black |
Strip length | 32 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 5 m |
Total number of potentials | 2 |
Type of cable | Control line 2 x 1 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 289.401 г |
Серия: 891 (100 из 1377)
- 891-8992/115-302 891-8992/115-401 891-8992/115-402 891-8992/115-501 891-8992/115-502 891-8992/115-601 891-8992/115-602 891-8992/115-701 891-8992/115-702 891-8992/115-801 891-8992/115-802 891-8992/116-101 891-8992/116-102 891-8992/116-201 891-8992/116-202 891-8992/116-301 891-8992/116-302 891-8992/116-401 891-8992/116-402 891-8992/116-501 891-8992/116-502 891-8992/116-601 891-8992/116-602 891-8992/116-701 891-8992/116-702 891-8992/116-801 891-8992/116-802 891-8992/205-101 891-8992/205-102 891-8992/205-103 891-8992/205-105 891-8992/205-107 891-8992/205-201 891-8992/205-202 891-8992/205-203 891-8992/205-205 891-8992/205-207 891-8992/205-301 891-8992/205-302 891-8992/205-303 891-8992/205-305 891-8992/205-307 891-8992/205-401 891-8992/205-402 891-8992/205-403 891-8992/205-405 891-8992/205-407 891-8992/205-501 891-8992/205-502 891-8992/205-503 891-8992/205-505 891-8992/205-507 891-8992/205-601 891-8992/205-602 891-8992/205-603 891-8992/205-605 891-8992/205-607 891-8992/205-701 891-8992/205-702 891-8992/205-703 891-8992/205-705 891-8992/205-707 891-8992/205-801 891-8992/205-802 891-8992/205-803 891-8992/205-805 891-8992/205-807 891-8992/206-101 891-8992/206-102 891-8992/206-103 891-8992/206-105 891-8992/206-107 891-8992/206-201 891-8992/206-202 891-8992/206-203 891-8992/206-205 891-8992/206-207 891-8992/206-301 891-8992/206-302 891-8992/206-303 891-8992/206-305 891-8992/206-307 891-8992/206-401 891-8992/206-402 891-8992/206-403 891-8992/206-405 891-8992/206-407 891-8992/206-501 891-8992/206-502 891-8992/206-503 891-8992/206-505 891-8992/206-507 891-8992/206-601 891-8992/206-602 891-8992/206-603 891-8992/206-605 891-8992/206-607 891-8992/206-701 891-8992/206-702 891-8992/206-703
8918992/205505, 891 8992/205 505
