Datasheet Wago 891-8993/116-101 — Даташит
Соединительный кабель; Розетка - свободный конец; 3-пол.; длиной 1 м; Кодирование А; безгалогенные; Концы проводников, припаянные: 9 мм
| 891-8993/116-202 Wago | по запросу | ||
| Coding | A |
| Цвет | black |
| Color of sheathed cable | black |
| Conductor preparation | tip-bonded |
| Connection type | Socket - free end |
| Connector color | black |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | PL |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 7.4 … 9.4 mm |
| Fire load | 1.732 MJ |
| GTIN | 4055143397551 |
| Ground function | with preceding GND contact |
| Halogen-free | Yes |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | L ⏚ N |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 3 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | L ⏚ N |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Strain relief color | black |
| Strip length | 40 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 1 m |
| Total number of potentials | 3 |
| Type of cable | H05Z1Z1-F 3G1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 101.519 г |
Серия: 891 (100 из 1377)
- 891-8993/106-202 891-8993/106-203 891-8993/106-205 891-8993/106-207 891-8993/106-301 891-8993/106-302 891-8993/106-303 891-8993/106-305 891-8993/106-307 891-8993/106-401 891-8993/106-402 891-8993/106-403 891-8993/106-405 891-8993/106-407 891-8993/106-501 891-8993/106-502 891-8993/106-503 891-8993/106-505 891-8993/106-507 891-8993/106-601 891-8993/106-602 891-8993/106-603 891-8993/106-605 891-8993/106-607 891-8993/106-701 891-8993/106-702 891-8993/106-703 891-8993/106-705 891-8993/106-707 891-8993/106-801 891-8993/106-802 891-8993/106-803 891-8993/106-805 891-8993/106-807 891-8993/115-101 891-8993/115-102 891-8993/115-201 891-8993/115-202 891-8993/115-301 891-8993/115-302 891-8993/115-401 891-8993/115-402 891-8993/115-501 891-8993/115-502 891-8993/115-601 891-8993/115-602 891-8993/115-701 891-8993/115-702 891-8993/115-801 891-8993/115-802 891-8993/116-101 891-8993/116-102 891-8993/116-201 891-8993/116-202 891-8993/116-301 891-8993/116-302 891-8993/116-401 891-8993/116-402 891-8993/116-501 891-8993/116-502 891-8993/116-601 891-8993/116-602 891-8993/116-701 891-8993/116-702 891-8993/116-801 891-8993/116-802 891-8993/205-101 891-8993/205-102 891-8993/205-103 891-8993/205-105 891-8993/205-107 891-8993/205-201 891-8993/205-202 891-8993/205-203 891-8993/205-205 891-8993/205-207 891-8993/205-301 891-8993/205-302 891-8993/205-303 891-8993/205-305 891-8993/205-307 891-8993/205-401 891-8993/205-402 891-8993/205-403 891-8993/205-405 891-8993/205-407 891-8993/205-501 891-8993/205-502 891-8993/205-503 891-8993/205-505 891-8993/205-507 891-8993/205-601 891-8993/205-602 891-8993/205-603 891-8993/205-605 891-8993/205-607 891-8993/205-701 891-8993/205-702 891-8993/205-703 891-8993/205-705
8918993/116101, 891 8993/116 101
