Datasheet Wago 891-8993/215-102 — Даташит
Соединительный кабель; Штекер - свободный конец; 3-пол.; длиной 1 м; Кодирование А; безгалогенные; Концы проводников, припаянные: 9 мм
| 891-8993/205-107 Wago | по запросу | ||
| Coding | A |
| Цвет | white |
| Color of sheathed cable | white |
| Conductor preparation | tip-bonded |
| Connection type | Plug - free end |
| Connector color | white |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | PL |
| Cross section of single conductor | 1 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 6.3 … 8 mm |
| Fire load | 1.472 MJ |
| GTIN | 4055143397346 |
| Ground function | with preceding GND contact |
| Halogen-free | Yes |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | L ⏚ N |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 3 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | L ⏚ N |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | black |
| Rated current | 10 A |
| Rated voltage (III / 3) | 250 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Strain relief color | white |
| Strip length | 40 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 1 m |
| Total number of potentials | 3 |
| Type of cable | H05Z1Z1-F 3G1 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 78.65 г |
Серия: 891 (100 из 1377)
- 891-8993/205-702 891-8993/205-703 891-8993/205-705 891-8993/205-707 891-8993/205-801 891-8993/205-802 891-8993/205-803 891-8993/205-805 891-8993/205-807 891-8993/206-101 891-8993/206-102 891-8993/206-103 891-8993/206-105 891-8993/206-107 891-8993/206-201 891-8993/206-202 891-8993/206-203 891-8993/206-205 891-8993/206-207 891-8993/206-301 891-8993/206-302 891-8993/206-303 891-8993/206-305 891-8993/206-307 891-8993/206-401 891-8993/206-402 891-8993/206-403 891-8993/206-405 891-8993/206-407 891-8993/206-501 891-8993/206-502 891-8993/206-503 891-8993/206-505 891-8993/206-507 891-8993/206-601 891-8993/206-602 891-8993/206-603 891-8993/206-605 891-8993/206-607 891-8993/206-701 891-8993/206-702 891-8993/206-703 891-8993/206-705 891-8993/206-707 891-8993/206-801 891-8993/206-802 891-8993/206-803 891-8993/206-805 891-8993/206-807 891-8993/215-101 891-8993/215-102 891-8993/215-201 891-8993/215-202 891-8993/215-301 891-8993/215-302 891-8993/215-401 891-8993/215-402 891-8993/215-501 891-8993/215-502 891-8993/215-601 891-8993/215-602 891-8993/215-701 891-8993/215-702 891-8993/215-801 891-8993/215-802 891-8993/216-101 891-8993/216-102 891-8993/216-201 891-8993/216-202 891-8993/216-301 891-8993/216-302 891-8993/216-401 891-8993/216-402 891-8993/216-501 891-8993/216-502 891-8993/216-601 891-8993/216-602 891-8993/216-701 891-8993/216-702 891-8993/216-801 891-8993/216-802 891-8994/005-103 891-8994/005-105 891-8994/005-107 891-8994/005-203 891-8994/005-205 891-8994/005-207 891-8994/005-303 891-8994/005-305 891-8994/005-307 891-8994/005-403 891-8994/005-405 891-8994/005-407 891-8994/005-503 891-8994/005-505 891-8994/005-507 891-8994/005-603 891-8994/005-605 891-8994/005-607 891-8994/005-703
8918993/215102, 891 8993/215 102
