Datasheet Wago 891-8994/005-207 — Даташит
Соединительный кабель; Розетка - штекер; 4-пол.; Кодирование B; длиной 2 м; с изоляцией из ПВХ
| 891-8994/005-507 Wago | по запросу | ||
| Coding | B |
| Цвет | pink |
| Color of sheathed cable | gray |
| Connection type | Socket - Plug |
| Connector color | pink |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 7.1 … 9 mm |
| GTIN | 4055143516280 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | 1 2 3 4 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Number of Poles | 4 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | 1 2 3 4 |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | white |
| Rated current | 10 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 2 m |
| Total number of potentials | 4 |
| Type of cable | Control line 4 x 1 |
| Type of cable assembly | Interconnecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 178.153 г |
Серия: 891 (100 из 1377)
- 891-8993/206-603 891-8993/206-605 891-8993/206-607 891-8993/206-701 891-8993/206-702 891-8993/206-703 891-8993/206-705 891-8993/206-707 891-8993/206-801 891-8993/206-802 891-8993/206-803 891-8993/206-805 891-8993/206-807 891-8993/215-101 891-8993/215-102 891-8993/215-201 891-8993/215-202 891-8993/215-301 891-8993/215-302 891-8993/215-401 891-8993/215-402 891-8993/215-501 891-8993/215-502 891-8993/215-601 891-8993/215-602 891-8993/215-701 891-8993/215-702 891-8993/215-801 891-8993/215-802 891-8993/216-101 891-8993/216-102 891-8993/216-201 891-8993/216-202 891-8993/216-301 891-8993/216-302 891-8993/216-401 891-8993/216-402 891-8993/216-501 891-8993/216-502 891-8993/216-601 891-8993/216-602 891-8993/216-701 891-8993/216-702 891-8993/216-801 891-8993/216-802 891-8994/005-103 891-8994/005-105 891-8994/005-107 891-8994/005-203 891-8994/005-205 891-8994/005-207 891-8994/005-303 891-8994/005-305 891-8994/005-307 891-8994/005-403 891-8994/005-405 891-8994/005-407 891-8994/005-503 891-8994/005-505 891-8994/005-507 891-8994/005-603 891-8994/005-605 891-8994/005-607 891-8994/005-703 891-8994/005-705 891-8994/005-707 891-8994/005-803 891-8994/005-805 891-8994/005-807 891-8994/006-101 891-8994/006-102 891-8994/006-103 891-8994/006-105 891-8994/006-107 891-8994/006-201 891-8994/006-202 891-8994/006-203 891-8994/006-205 891-8994/006-207 891-8994/006-301 891-8994/006-302 891-8994/006-303 891-8994/006-305 891-8994/006-307 891-8994/006-401 891-8994/006-402 891-8994/006-403 891-8994/006-405 891-8994/006-407 891-8994/006-501 891-8994/006-502 891-8994/006-503 891-8994/006-505 891-8994/006-507 891-8994/006-601 891-8994/006-602 891-8994/006-603 891-8994/006-605 891-8994/006-607 891-8994/006-701
8918994/005207, 891 8994/005 207
