Datasheet Wago 891-8994/206-405 — Даташит
Соединительный кабель; Штекер - свободный конец; 4-пол.; Кодирование B; длиной 4 м; с изоляцией из ПВХ
| 891-8994/206-705 Wago | по запросу | ||
| Coding | B |
| Цвет | light green |
| Color of sheathed cable | gray |
| Conductor preparation | tip-bonded |
| Connection type | Plug - free end |
| Connector color | light green |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 8.4 … 10.5 mm |
| GTIN | 4055143520324 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | 1 2 3 4 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Note on rated current | 13 A for 3-pole load10 A for 4-pole load |
| Number of Poles | 4 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | 1 2 3 4 |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | white |
| Rated current | 16 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 38 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 4 m |
| Total number of potentials | 4 |
| Type of cable | Control line 4 x 1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 444.338 г |
Серия: 891 (100 из 1377)
- 891-8994/116-501 891-8994/116-502 891-8994/116-601 891-8994/116-602 891-8994/116-701 891-8994/116-702 891-8994/116-801 891-8994/116-802 891-8994/205-103 891-8994/205-105 891-8994/205-107 891-8994/205-203 891-8994/205-205 891-8994/205-207 891-8994/205-303 891-8994/205-305 891-8994/205-307 891-8994/205-403 891-8994/205-405 891-8994/205-407 891-8994/205-503 891-8994/205-505 891-8994/205-507 891-8994/205-603 891-8994/205-605 891-8994/205-607 891-8994/205-703 891-8994/205-705 891-8994/205-707 891-8994/205-803 891-8994/205-805 891-8994/205-807 891-8994/206-101 891-8994/206-102 891-8994/206-103 891-8994/206-105 891-8994/206-107 891-8994/206-201 891-8994/206-202 891-8994/206-203 891-8994/206-205 891-8994/206-207 891-8994/206-301 891-8994/206-302 891-8994/206-303 891-8994/206-305 891-8994/206-307 891-8994/206-401 891-8994/206-402 891-8994/206-403 891-8994/206-405 891-8994/206-407 891-8994/206-501 891-8994/206-502 891-8994/206-503 891-8994/206-505 891-8994/206-507 891-8994/206-601 891-8994/206-602 891-8994/206-603 891-8994/206-605 891-8994/206-607 891-8994/206-701 891-8994/206-702 891-8994/206-703 891-8994/206-705 891-8994/206-707 891-8994/206-801 891-8994/206-802 891-8994/206-803 891-8994/206-805 891-8994/206-807 891-8994/216-101 891-8994/216-102 891-8994/216-201 891-8994/216-202 891-8994/216-301 891-8994/216-302 891-8994/216-401 891-8994/216-402 891-8994/216-501 891-8994/216-502 891-8994/216-601 891-8994/216-602 891-8994/216-701 891-8994/216-702 891-8994/216-801 891-8994/216-802 891-8995/005-103 891-8995/005-105 891-8995/005-107 891-8995/005-203 891-8995/005-205 891-8995/005-207 891-8995/005-303 891-8995/005-305 891-8995/005-307 891-8995/005-403 891-8995/005-405 891-8995/005-407
8918994/206405, 891 8994/206 405
